Kenmore Fridge Not Cooling, Freezer Ok - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-30-2008, 08:00 PM   #16
Rewards Points: 150
Originally Posted by bobvanhalder View Post
Sorry. Dumb me. I don't know which of the refrigerants I use. To me it doesn't matter as I would replace the fridge before I would invest in a vacuum pump and the other equipment nesessary to reclaim the refrigerant. I was there a very long time age. Back in the Freon days.
look at you tag,,model# serial # ,,,mine says 134A on it
comp is offline   Reply With Quote
Old 06-30-2008, 09:05 PM   #17
Sorry, fridge is a rental so I probably won't see it again for a few days.
bobvanhalder is offline   Reply With Quote
Old 06-30-2008, 09:15 PM   #18
Rewards Points: 150
than ain't your paper work in a file
Old 07-13-2008, 03:55 PM   #19
Have you tried to blow the dust,pet hair,etc from the condensor coils.
remod is offline   Reply With Quote
Old 07-20-2008, 06:52 AM   #20
Rewards Points: 150
updates ????
Old 10-22-2008, 11:36 PM   #21
If the drain is clogged, try clearing out the tube with compressed air. You can use a steamer with a long quarter inch tube and run the tube down the drain and clean it out with steam. A turkey baister and water will work also.
sv9779 is offline   Reply With Quote
Fridge not cooling - evap fan? oppiecat Appliances 4 07-02-2013 04:19 PM
Kenmore fridge not cooling, freezer ok bobvanhalder HVAC 7 10-22-2008 10:52 PM
Fridge not cooling, help please Bcoleman6 Appliances 4 01-30-2008 09:02 AM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 09:55 AM
