Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 06-30-2008, 10:00 AM   #1
Default Kenmore fridge not cooling, freezer ok
Kenmore model 253.62812202 Top Mount Refrigerator. Freezer ok. Fan for fridge not running. I took the cover for the evaperator coils off and the fan started running. I did notice that the coils had some ice on them and there was some ice in the drain. I removed the ice in the drain and assumed the defrost would take care of the coils.
Now a week later the renter calls me and says the fridge is not working again. Obviously there is something else wrong. I have told the renter to empty the freezer, leave the freezer door open, and unplug the fridge for for 3 or 4 hours. I'm thinking that this will get the fridge running again for them temporally, but I need a logical plan to figure out what is wrong.
Any ideas?
Thanks very much.
bobvanhalder is offline   Reply With Quote
Old 06-30-2008, 01:01 PM   #2
try thawing it out ,,completely,,, it has mine working again
comp is offline   Reply With Quote
Old 06-30-2008, 01:12 PM   #3
Thanks Comp,
Are you saying that you replaced no parts and the fridge is still working ok? Makes me wonder why it happened in the first place, but then, I'm that kind of guy.
Old 06-30-2008, 01:20 PM   #4
Originally Posted by bobvanhalder View Post
Thanks Comp,
mine doesn't drain right ,,look at my thread
i let it sit open almost 3 days,,,the door seal was even froze an didn't seal right,,now it does
Old 06-30-2008, 01:41 PM   #5
Guess I am not following this too well. I had't read anything about you defrosting for 3 days or the frozen door.
Would you explain to me how I can read that?
A Newbe!!
Old 06-30-2008, 02:22 PM   #6
A Newbe!!
i started a thread about mine ,,i updated it and saw yours
OK ,,SO tends to PACK the frig (i hate that) it started to ice up awile back and i cleaned it out,, ,when it iced i'm guessing it messed up the drain so all the water was being put right back into it ,,,,,,,froze up faster and faster..it got to the point the frig was about 48degs at its coolest, must have froze up in the walls to,,,,i took everything out packed it in coolers and unpluged it and used a blow dryer on it ,looked great waited 2 more days,,to thaw it completely,,,,now its at 34-36 degs in the frig part at only the 5 setting.... but i'm cleaning out the water every day
cause of it draining into the bottom,,its aint that bad to do,and i don't have the $$$ to replace it
Old 06-30-2008, 02:36 PM   #7
Thanks for the info. Maybe that will take care of mine too!
By the way, I did read on the Net that some of the Kenmore fridges have a seal problem with the drain line that ends up causing what you have (water in the fridge). I wish I remembered better, but it seem to me that the fix was to install "a tinfoil type of material" over the existing seal. I'm not really sure what that means, but I have seen that tinfoil stuff before. It has an adhesive on one side. Maybe one of your appliance stores around you will know about it. I have found some of those parts people know quite a bit about the parts they sell.
Old 06-30-2008, 02:50 PM   #8
thanks i'll ask more questions,,,,i didn't pull all the panels cause i saw the ice,,and was afraid of busting something,,the door gasket is a 100 dollar save alone i lost more food before i thawed than the 3 days using coolers to
Old 06-30-2008, 04:12 PM   #9
If your fridge is like mine, it comes apart easily. There are 4 screws holding the back cover in place, and there are 4 screws holding the controls to the top. The control piece drops down and then you can easily slip the drain tube out of the slip fit drain tube. If you wish to take the control piece out of the fridge, there is one plug to disconnect. You might want to make yourself familiar with the timer (just in case). There should be a knob or screw or something to turn.
If in the future the evaporator coils freeze up again, when the compressor is running, turn the knob (screw) on the timer until the compressor stops. At that point you have entered the defrost cycle.
I only mention all of this as it makes it a lot easier to figure out what is not working.
Old 06-30-2008, 04:26 PM   #10
ours are different ,,,,but trying the defrost didn't work at all had to open it up tto thaw ,,that ice must have incased the frig walls
Old 06-30-2008, 06:00 PM   #11
If you know that, then you have just about figured out what is wrong. When in the defrost cycle measure for voltage going to the defrost coil. If you have voltage the timer is good and the problem is in the defrost loop. That might be the coil or the bi-metal.
But you said you were taking water out of the fridge every day. That water means that your defrost works but that you are not draining. Seems to me that you have a plugged drain tube.
Old 06-30-2008, 06:04 PM   #12
that or as the ice expaned it messed it up i'll open it up when i have fewer projects or it acts up again ,,,,,oh is yours 134A ?
Old 06-30-2008, 06:13 PM   #13
What is a 134A? If that's part of a model number, then no.
By the way, that drain tube goes down to a pan above the compressor and then evaporates. I'll bet that pan hasn't seen any water in a long time.
Old 06-30-2008, 06:14 PM   #14
the refrigerent
Old 06-30-2008, 06:44 PM   #15
Sorry. Dumb me. I don't know which of the refrigerants I use. To me it doesn't matter as I would replace the fridge before I would invest in a vacuum pump and the other equipment nesessary to reclaim the refrigerant. I was there a very long time age. Back in the Freon days.
More On This Topic
Many auto repair kits contain battery-powered air compressors, which can be used to pump up a tire when it goes flat. They are simple to use and don't require much dexterity, though they may pose difficulties if you're not mechanically inclined. Read More »
Learn how to clean the volume pots (knobs) on a fender stratocaster electric guitar in this diy guitar tech video. Read More »
I'm Fernando we are here with Expert Village and we are going over setting the control for your timer. Now with your timer each timer is individual and it comes with actual instructions if you are not familiar with how to operate this timer we ask that... Read More »
Today we're changing an air conditioning compressor on a '96 Ford Explorer. In this step, I'm going to demonstrate the proper service procedure for removing the manifold from the back of your air conditioning compressor. The AC manifold is located right... Read More »
Hi, my name is Mark Delgado with American Auto Service for Expert Village. You'll have high pressure in the high side when you have restrictions also. That may mean that in the orifice tube, if the compressor is starting to put debris into the system, it... Read More »
Kenmore fridge not cooling, freezer ok bobvanhalder HVAC 7 10-23-2008 12:52 AM
Kenmore top freezer recirc. fan doesn't run ndug33 Appliances 0 06-19-2008 03:14 AM
Fridge not cooling, help please Bcoleman6 Appliances 4 01-30-2008 11:02 AM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 11:55 AM
Fridge not cooling - evap fan? oppiecat Appliances 3 12-06-2006 08:46 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
