Kenmore Fridge Not Cooling But Freezer Is Working Perfectly. - Appliances - DIY Chatroom Home Improvement Forum
Old 07-21-2010, 10:00 PM   #1
Kenmore fridge not cooling but freezer is working perfectly.
I have a Kenmore bottom freezer refrigerator and the fridge will not go below room temp. but the freezer is working perfect and i replaced the control unit for the temp setting and that did not work. So what should I check or replace to get my fridge to cool again?
l.shemon is offline   Reply With Quote
Old 07-22-2010, 06:34 AM   #2
the Musigician
DangerMouse's Avatar
Check the fan. It's probably not working to draw the freezer air into the fridge area.
DM
Old 07-22-2010, 04:11 PM   #3
Household Handyman
Rewards Points: 1,408
I agree with DM as to checking the fan. Then, IF the fan is working, check the duct work which allows the fan to blow the cold freezer air into the fridge part. I had a small pack of meat get into my duct work once causing this same problem with a top freezer unit. When I took the cover over the fan off, there was this one hamburger patty in there in a zip-lock. No air moving. Remove patty, replace cover, cook patty, all is well. David
Old 07-22-2010, 04:26 PM   #4
the Musigician
No doubt thinking to yourself "Now how the heck did THAT get in there????" LOL
DM
Old 09-17-2010, 03:34 PM   #5
l.shemon: What was the eventual solution to your problem? Was it the fan?
donnoit is offline   Reply With Quote
Old 06-03-2011, 11:54 PM   #6
i found this topic because i have a similar problem with a bottom freezer kenmore fridge. freezer is ok but the fridhge part is not cooling .
i took off the freezer cover and found a small part like a sensor with 2 wires .
this sensor is sittng on the freon tube and looks like it blew up .
i took a picture of it and attached it to this posting.
Can anobody identify what this part is and if what the problem with cooling is caused by?
thanks a lot.
tiras is offline   Reply With Quote
Old 06-08-2011, 10:02 AM   #7
the Musigician
If it's blown, take it to an appliance repair shop and get another one. Replace and see if the problem is solved.
DM
Old 06-08-2011, 12:47 PM   #8
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
that would be your self defrost terminator, it is bad and it will cause the problem you described
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
DangerMouse (06-08-2011)
Old 06-08-2011, 03:08 PM   #9
I have the same problem with mine the freezer works perfect but the refrigerator doesn't I can hear the fan working but not air coming to the top. The freezer is clean no ice in the back. So I don't think is because of that. Please need help any other advice to what to look for
Bolo487 is offline   Reply With Quote
The Following User Says Thank You to Bolo487 For This Useful Post:
mmfreer (10-11-2012)
Old 06-08-2011, 04:33 PM   #10
the Musigician
Did you physically inspect the fan? It may just be the compressor running you hear.
DM
Old 06-09-2011, 06:58 AM   #11
You have to post model/serial #'s otherwise it's like saying "my car doesn't run-what could it be?" some refrigs use two fans, dampers, separate evaporators-yada-ya..
Jacques is offline   Reply With Quote
Old 06-09-2011, 02:14 PM   #12
it was it - defrost thermostat. I replaced it and now everything is ok.
thanks for your help.
Old 06-09-2011, 02:29 PM   #13
the Musigician
And Thank YOU for returning and letting us know! We love happy endings here, and always like to know when we've actually done some good! LOL
DM
Old 11-26-2011, 04:50 PM   #14
I have the same problem as I am reading above, Kenmore Bottom-Mount Refrigerator, model # 31912, freezer fine, no ice build up, fan working okay, no defrost thermostat that I can find after taking off all back covers, but no air coming into frig unit? Please help. Thank you.
Fetz is offline   Reply With Quote
Old 08-26-2013, 07:00 PM   #15
Kenmore Refrigerator is not Cooling
I have a Kenmore Bottom Freezer (Model #795). The freezer is working; however the refrigerator is not cooling. I used to get an error message whenever the refrigerator stopped working. Now, my refrigerator reflects a 37 degrees; however, the refrigerator is not cooling to 37 degrees. What can I do to resolve this issue?
QuicheLo is offline   Reply With Quote
kenmore in freezer ice maker not working fullthrottle Electrical 2 07-02-2010 06:40 PM
admiral fridge freezer gc2224gekb stopped working bazzra Appliances 0 04-20-2010 02:16 PM
Kenmore fridge not cooling, freezer ok bobvanhalder Appliances 20 10-23-2008 12:36 AM
Kenmore fridge not cooling, freezer ok bobvanhalder HVAC 7 10-22-2008 11:52 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 10:55 AM
