Kenmore Fridge Freezing Food Section - Appliances - DIY Chatroom Home Improvement Forum
Old 02-11-2014, 03:05 PM   #1
Kenmore Fridge Freezing food Section
I have a 10 yr old side by side 106 56532400 Kenmore that is running at about 32-33f in the refridge section. Freezer is at 0 f.
My fridge has the electronic push button temp controls.
When I adjust the fridge to 1, it still stays at 32/33 24 hrs later.
I can't seem to be able to get into self-diagnostic mode, although I tried suggestions from other posts. I think it may be the damper, as it appears open. The damper does not have a rod going to the front of the fridge, so seems to be self contained.
Anybody have any ideas to diagnose this? I have meds that can't be frozen, and have them in the door section...and I open the door a lot to keep them from freezing.
tjb3653 is offline   Reply With Quote
Old 02-12-2014, 06:16 PM   #2
update
I took the damper cover off, and tried testing the thermistor in the unit. I placed it in ice-water, and my ohm meter showed the thermistor as "open" (in, and out of the ice-water). Anybody tell me if I'm on the right track?
Thanks.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Basment fridge receptacle JKeefe Electrical 14 12-18-2013 10:30 AM
Seeking advice on repaired drywall section painting shdowflare Painting 9 12-16-2011 04:55 PM
Kenmore fridge stops cooling with frost in freezer donnoit Appliances 3 09-20-2010 08:59 AM
Replacing Section of Sole Plate RM575 Carpentry 3 03-28-2010 10:31 AM
