Kenmore Freezer Not Freezing Completely - Appliances - DIY Chatroom Home Improvement Forum
Old 05-12-2011, 06:08 PM   #1
Kenmore Freezer not freezing completely
I have a Kenmore Model 106.73854302 not sure how old it is, at least 5 years old (came with the house). Recently I defrosted the freezer to clear an ice dam in the drain tube for the defrost cycle. the freezer has operated just fine for about 2 weeks, now it only cools to just above 34 degrees. The freezer fan is functioning properly. Any ideas of what to check or look for?
Thanks,
Rich
rich kahl is offline   Reply With Quote
Old 05-12-2011, 06:55 PM   #2
When was the last time you vacuumed behind the fridge? Also remove back cover and do the coils, carefully, at the same time.
VIPlumber is offline   Reply With Quote
Old 05-12-2011, 10:14 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
look on the back wall of the freezer, is it covered with frost? My bet is you have a problem with your self defrost.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Kenmore 596 bottom freezer cold top warm klimshelf HVAC 2 03-30-2011 09:32 AM
Kenmore fridge stops cooling with frost in freezer donnoit Appliances 3 09-20-2010 08:59 AM
Kenmore fridge not cooling, freezer ok bobvanhalder Appliances 20 10-23-2008 12:36 AM
Kenmore fridge not cooling, freezer ok bobvanhalder HVAC 7 10-22-2008 11:52 PM
Freezer on top, not freezing any more. kgphoto Appliances 7 06-23-2008 11:00 PM
