Kenmore F1 Code - Appliances - DIY Chatroom Home Improvement Forum
Old 08-17-2008, 10:18 AM   #1
Rewards Points: 150
Kenmore F1 Code
I have a Kenmore model #: 790.95410100 , Serial # VF12414905 and am getting the F1 code.
When I turn the power on the the oven the lower heating element will burn bright red no matter what temp the oven is on. It did this 2 years ago and I turn the breaker off and back on and it was fine. It did it out of the blue last night while making dinner. It burned dinner and no matter how many times I turn it off or on via the breaker it will still turn on that lower element and no matter which buttons you push it leaves the element on.
From what I read the ERC needs to be replaced. Does that sound right to you? Here are some pics of my stove.
twilightcall is offline   Reply With Quote
Old 08-19-2008, 08:13 AM   #2
jeff1's Avatar
Hi,
A Frigidaire built Kenmore.
Either a melted/shorted wire or bad control keeping the element on.
Electronic clock control
Overlay - clock, black
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 08-19-2008, 08:50 AM   #3
Rewards Points: 150
I replaced the EOC (electronic oven control unit) and the oven temp sensor. It works like new now. Just in case anyone else has this issue: The EOC was $161.00 from a local supplier and the oven temp sensor was $26.00. You can get the EOC for $129.00 online but I needed it right away. It is easy to change. (4 phillips screws). The oven temp sensor requires you to remove the large panel on the back of the range and has 2 screws holding it in. From what I read the electronic control units break a lot. Hope this helps someone down the road.
Old 08-20-2008, 08:12 AM   #4
jeff1's Avatar
Thankx for the update
jeff.
JRAppliance
www.jrappliance.ca
new HE5 kenmore washer sninny Appliances 4 08-08-2008 04:24 PM
Stairway landing code question. Bcoleman6 Building & Construction 4 06-26-2008 10:43 AM
underground code tom b Electrical 8 03-23-2008 11:55 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 02:47 PM
code question JustJoe Building & Construction 3 01-27-2007 10:06 AM
