Kenmore Elite HE3 Electric Dryer Runs But No Heat - Appliances - DIY Chatroom Home Improvement Forum
Old 10-20-2013, 08:57 PM   #1
Kenmore Elite HE3 electric dryer runs but no heat
Hi everyone,
this is about the 3rd time for this problem with something different each time. First was a thermistor, then heating element. Now it happened again, I checked element with Ohm meter and it is good, replaced thermistor and still no luck. Checked thermal fuse with Ohm meter and it was good.....I hear there are 2 fuses but I don't know where the 2nd one is.....any ideas? I hate appliances!
Smoke is offline   Reply With Quote
Old 10-21-2013, 03:18 PM   #2
K&B Designer
Live_Oak's Avatar
When was the last time you cleaned out your dryer duct from the back of the machine all the way through where it exits the house? Anytime I hear of a bunch of complaints relating to the element or thermistors burning out, that's usually the actual source of the problem that the failures are the symptom of.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 10-21-2013, 05:06 PM   #3
Rewards Points: 13,296
You need to post the whole model #.
Old 10-21-2013, 06:38 PM   #4
Thanks for replies...Model is 1182822100. The last time the underside\backside and pipe was cleaned was about 9 months ago when it was the heating element problem. What I DO know is that I need to change the pipe coming out the back because I have "accordion" style hose which they all say is no no. Now what is weird, when you go to Lowe's they sell the same stuff for "Dryer Vents" hose....
Old 10-22-2013, 12:40 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Verify that you have 240 volts at the cord connections on the back of the dryer. The dryer only needs 120 volts to turn the motor and operate the controls but needs 240 to heat.
Coastal South Carolina
rjniles is offline   Reply With Quote
Heat Pump Aux. Heat not wired correctly / at all? woodardhsd HVAC 12 02-24-2013 09:26 AM
Heat won't stop running, just installed new thermostat NorthSidePK HVAC 28 11-01-2012 11:05 AM
GE Electric Dryer won't shut off in auto/high heat mode jktbnelson Appliances 7 01-15-2011 08:39 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
