Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 07-04-2012, 03:03 PM   #1
kenmore elite gas range
hello,i have a kenmore elite model number 3107 all of the burners are operating, the led pad is working, but i can't get the oven to go the upper element will not go on either i have checked all of the house fuses.
is there a fuse that is in the stove?
if the pilot light might be off, how and where to relight?
thanks chris
btw we have just moved into this new home and we have never had a gas stove
christoff is offline   Reply With Quote
Old 07-04-2012, 04:48 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Newer stoves use electronic ignition. There has not been a standing pilot on stoves for over 30 years now. What is probably bad is either the circuit board that controls the oven circuit, or the igniter.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 07-04-2012, 10:15 PM   #3
Gas burners will have a glowbar ignition system that will draw approx 3.4 amps. It is most likely that the glowbar has failed. Check each glowbar to ensure that they are drawing the proper current. The pilot will not ignite or prove without the glowbar operating correctly (drawing the proper current and being at the right temperature)
If you are inexperienced with gas equipment, you should have a technician take a look at it.
Here is the installation manual. It has a little bit of information on the unit.
Protocol. is offline   Reply With Quote
Old 07-12-2012, 08:12 AM   #4
the thermal breaker was tripped, i looked at the wiring diagram that i got and it shows the breaker wired in series with the bake, broil, and convection circuits so when it popped the breaker it took out the 3 circuits. apparently when you use the self clean feature it pops the breaker so i took the rear panel off and checked it with an ohm meter and there was no reading, but i was fortunate that it had a reset button it pushed it and everything worked after refitting the rear panel
Kenmore range burner ignitors not working Eagle One Appliances 16 07-24-2012 05:08 PM
New Kenmore Range 790.92604 wide fluctuation in oven temp tkolarik Appliances 5 09-10-2011 09:17 AM
Old gas kenmore range....no oven, but burners work shadango Appliances 24 11-17-2010 07:45 AM
Kenmore Elite refridgerator not distributing ice itr324 Appliances 0 10-16-2009 05:47 PM
Need help replacing EOC on Kenmore Range mjpfeiffer Appliances 1 02-10-2009 11:46 PM
