Kenmore Dryer Problem - Appliances - DIY Chatroom Home Improvement Forum
Old 02-22-2009, 02:56 PM   #1
I have a Kenmore Model#110 60724990. Wife has been complaining that its taking 3 cycles to get the clothes dry. Checked venting and airflow first and it appears OK. I pulled the back off and checked the element, it has continuity and I also benched checked it and it appears to be working fine. I noticed when I run the dryer the element heats abot 20 seconds and then cycles off so I am assuming its a thermostat or limit switch of some sorts.
I went on Sears web site and they showed internal-bias 150-F thermostat, a 250-F thermostat and a Thermo cut-off hi-limit thermostat. I'm not really sure where to go from here.
Any help would be appreciaited.
ElectricianJeff is offline   Reply With Quote
Old 02-23-2009, 07:33 AM   #2
I would detach the dryer from the vent and then inspect the underside blower for blockage. Then plug it back in and run it inside with a nylon over the eaxhaust with two equal loads, one on timed dry one on auto dry. If it drys on timed dry and not on auto I would suspect humidity sensor is cutting out the auto cycle. If it fails to dry in both settings I would suspect the limit switch.
When you're in there, save a trip check your bushings and belt as well tehy need inspection anyway...
Chemist1961 is offline   Reply With Quote
Kenmore (Whirlpool) refrig ice maker problem lexort Appliances 18 05-07-2016 10:28 AM
Kenmore ice maker problem Jrocket Appliances 8 02-28-2009 08:31 PM
Help with serious flooding problem MNUZZI Landscaping & Lawn Care 12 10-03-2008 03:46 PM
GMP100-3 Problem hansim4 HVAC 2 12-13-2007 04:55 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
