Kenmore Dryer Keeps Burning Up The Fuse - Appliances - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 10:21 PM   #1
Question
Kenmore Dryer Keeps burning up the fuse
It burned up the Thermal Fuse and when I would turn the dryer on the coil would heat up but the motor would not turn the drum. I replaced the fuse along with the thermostat & cut off fuse and things worked fine for one load. Now it acts the same way. This whole time I have noticed that the dial does not stop at the end of the cycle it continues to turn, seems like until it gets back to straight up at the top. Could the timer be causing this?
Is the motor just worn out and pulling to much juice?
Bought the dryer new about 7 years ago.
Appreciate any advice
Kenmore Model #110-67522600
jones6826 is offline   Reply With Quote
Old 04-08-2013, 04:03 PM   #2
Rewards Points: 744
How did you verify that the thermal fuse was blown? If the the thermal fuse was blown, then the coil would not be able to heat up.
http://www.repairclinic.com/Kenmore-...-Breaker-Parts
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
I assume you have checked that nothing is obstructing the blower's airflow? Blower is working properly?
Seattle2k is offline   Reply With Quote
Old 04-08-2013, 04:20 PM   #3
When i said the thermal fuse I was talking about the fuse behind the motor. I replaced the motor and all is well for now.
Thanks for the reply
Old 04-08-2013, 06:07 PM   #4
Rewards Points: 744
Thanks for replying back with your solution! Glad to hear that you're back in business.
Old 04-08-2013, 08:21 PM   #5
Unhappy
Spoke to Soon
I just thought i had it fixed. Spoke to soon. As I said in the original post "the dial does not stop at the end of the cycle it continues to turn, seems like until it gets back to straight up at the top."
We usually run it in the timed section. An example of the problem would be if you had started the dryer at 50 minutes and opened the door at 20 and removed the clothes then shut the door without restarting the dryer. The heater coil continues to stay hot while the door is open and closed until the timer reaches zero. Then the timer continues to click all the way back around to just before timed section starts.
Does the timer need to be replaced or is there something causing the timer to do this?
Again I appreciate any help
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
Burning smell from dryer bucksone Appliances 9 11-02-2012 03:34 PM
Noisy Kenmore Dryer Skeeter01a Appliances 2 02-22-2010 07:05 PM
Dryer Pony Problem. Hobb3s Electrical 17 09-30-2008 08:16 PM
Problems with new fuse box for a dryer. needsomehelp Electrical 12 04-10-2008 11:20 PM
