Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-05-2011, 04:55 PM   #1
In a little over my head
kenmore dishwasher problem
It looks like I found the problem. An open bi-metal thermal switch. Now the question: what's the root cause? What's the most likely cause for this thing to trip?
My Kenmore/Whirlpool dishwasher is on the blink again. When it works it's great. But it frequently doesn't. Symptom was random flashing lights on the display. A controller fixed it for a few months. Then a keypad fixed it for a few more. Last night it stopped mid-cycle, display is dark. Receptacle has power. Latch switches check OK.
I'd love a tip to get it fixed. I'm just as interested in any recommendations on a dishwasher that will continue to work beyond the warranty period.
Thanks!
ratherbefishing is offline   Reply With Quote
Old 12-11-2011, 10:29 PM   #2
Any ideas what might cause the non-resettable bimetal to open?
Old 12-12-2011, 05:31 AM   #3
That's a safety for too hot in control area. it usually fails though due to bad wiring connections. they have a model specfic repl kit-if you DIY follow all instructions exactly.
Jacques is offline   Reply With Quote
Old 12-12-2011, 05:03 PM   #4
So the kit replaces more than just the bi-metal device? Would this be a Sears only part or available from the local Appliance Repair Parts store?
Old 12-12-2011, 07:52 PM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
kit should consist of 2 new door switches a wire receptacle block and disc. Any appliance store should be a ble to get it
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 12-12-2011, 07:59 PM   #6
hate to say it.... get a new dishwasher you have had to many issues with this lemon "its a money pit"
Old 12-12-2011, 11:14 PM   #7
Ben, I was thinking the same thing. I'm ready to paint a lemon on the door and chain it to the lightpost in front of Sears. But this repair is just $25. I figure I'll try it. Besides, my wife picked up the part already. I'm curious why the kit's instructions have you cut the wire and use a junction block, rather than just plug it into the existing harness. Maybe someone at Whirlpool can answer that if I call. The folks at Sears sure can't.
Old 12-12-2011, 11:39 PM   #8
#1 HAWKEYE FAN
because high amperage runs through these wires and door switches. Usually when the thermal disc blows like yours did the wires are also burnt/ melted/ discolored from heat etc. The only way to insure a lasting repair is to cut all these wires and use the block to get a tight connection.
Old 12-14-2011, 01:35 PM   #9
I put in the new thermal breaker last night. Dishwasher works great again. Thanks for everyone's help. I even have a theory why the other components failed. A couple of weeks ago, I was hooking up the wires, at the panel, to the new addition. I found a loose neutral. It was making connection, until it got bumped. I worked my way across the bus, tightening screws. Only one loose one, but it went to the kitchen.
I'm keeping my fingers crossed.
kenmore dishwasher cut out, won't drain, no power jess1974 Appliances 3 12-28-2010 07:45 PM
Kenmore dishwasher shoots water out the side! tigerbalm2424 Appliances 7 02-02-2010 08:55 PM
Kenmore washer problem wink25 Appliances 1 03-16-2009 08:02 PM
Kenmore Dryer Problem ElectricianJeff Appliances 1 02-23-2009 07:33 AM
Kenmore Ultra Wash Dishwasher mystery rtyui2 Appliances 3 05-29-2008 11:35 AM
