Kenmore 700 Series Washer Won't Agitate, Spin Or Drain??? - Appliances - DIY Chatroom Home Improvement Forum
Old 08-12-2013, 05:30 PM   #1
Kenmore 700 series washer won't agitate, spin or drain???
I have a kenmore 700 series washer model number 11027741600 and after filing it will not do anything else just hum...please help someone
LORALIE is offline   Reply With Quote
Old 08-12-2013, 06:26 PM   #2
Rewards Points: 42
The transmission is probably shot. If you are able, pull the washer out of its spot and see if there is oil on the floor.
Dan
djlandkpl is offline   Reply With Quote
Old 08-12-2013, 08:07 PM   #3
hey dan did that and not oil, someone told me that it could be the timer
Old 08-12-2013, 08:21 PM   #4
Rewards Points: 42
Could be. If you manually turn the timer does the machine start working?
Dan
Old 08-12-2013, 08:44 PM   #5
no it just hums, it will fill up with water but then nothing
Old 08-12-2013, 08:50 PM   #6
Rewards Points: 42
If manually turning the control doesn't do anything it's possible that the timer is bad or it's the transmission. Time for a service call.
Dan
Horizontal Washer Drain AFTER Standpipe 3 inch?????? hammerlane Plumbing 23 11-01-2011 09:06 PM
tie in washer drain to toilet? markallan Plumbing 0 02-22-2011 07:40 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
Water heater drain pan - can I drain into the washer drain? cjartguy Plumbing 7 04-15-2009 02:34 PM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
