Kenmore 70 Series Washer: Whine During Spin Cycle Then Stopped During Agitate - Appliances - DIY Chatroom Home Improvement Forum
Old 02-02-2014, 07:25 PM   #1
Rewards Points: 93
Kenmore 70 series washer: whine during spin cycle then stopped during agitate
I've got a 70 series Kenmore washer model 110.26732503. It was making a whining noise during a spin cycle but otherwise seemed OK. My wife put another load in and it stopped while agitating. There was a burning/hot smell coming from it. It's a direct drive so not belt to burn up. I got the cabinet off and there was a ten inch circle of oil underneath and a few drops on the transmission. The oil didn't look like it just leaked, more like it had accumulated over time.
Any thoughts? Bad coupling? Bad transmission?
scottyv81 is offline   Reply With Quote
Old 02-03-2014, 06:27 PM   #2
Rewards Points: 93
Update: I pulled the pump off and the washer spun when I put it on a spin cycle. I then took the hoses off the pump and looked inside and found a baby sock stuck in there. I pulled it out and put the pump back on and the washer spun. I didn't let it fill to see if it would agitate because I didn't want to have to drain it again.
Is it in my best interest to replace the clutch or coupler since I have it apart? Or should I reassemble and give it a shot?
Kenmore Portable Washer Won't drain or spin nlinda Appliances 1 08-20-2013 11:13 AM
Kenmore washer wkdesilva81 Appliances 1 05-13-2012 11:13 AM
Kenmore washer won't spin TNFrank Appliances 5 01-12-2011 07:03 AM
Kenmore washer won't drain diggitydog Appliances 3 10-16-2010 10:46 PM
ugh.... my kenmore washer won't fill with water! diy'er on LI Appliances 6 09-05-2010 07:28 PM
