Kenmore 596.58695890 Cooling Issues - Appliances - DIY Chatroom Home Improvement Forum
Old 07-25-2009, 11:26 AM   #1
kenmore 596.58695890 cooling issues
Hello,
I seem to be having some cooling issues with my kenmore 596.58695890. Last year the condensor fan wasn't working, so I had to replace the control for that. Now I've noticed it's not quite getting cold enough, some things are thawed a bit. Sometimes it's plenty cold, sometimes it's not.
I removed the back panel, and the top half was frosted but not the bottom. Fan wasn't running, closed it for a minute, walked away and the fan was running. Did a manual advance to defrost mode and that kicked in and definitely works as it heated up the coils and defrosted them completely.
Advanced it again so it should be cooling, but the evaporator fan isn't running again. I'm not sure if that should always be running, or if it just runs at certain times during cooling mode. I know it was working earlier, just doesn't seem to run all the time, so not sure if that's my problem again.
Thanks in advance.
mindraven is offline   Reply With Quote
Old 07-25-2009, 12:51 PM   #2
As a followup to this I did test for power at the 2 leads going to the motor that controls the fan. All I have is a cheapo tester, same I used last year, that shows AC110V and AC220V. I believe last year it showed power to here when the motor was bad.
This time I'm not showing anything at those 2 leads, but the fan was definitely running earlier in the day. Reading in some of the forums this sounds like it might be something to do with the defrost thermostat maybe? But not sure how to test that.
Old 07-25-2009, 01:21 PM   #3
And now the fan is running again, about an hour and a half after it's been in cooling mode and the freezer being up around 45 degrees at the very top. So, I think I'm going to order a new defrost thermostat sometime this weekend, but if someone wants to chime in to confirm my suspicions that would be great
Old 07-27-2009, 08:31 AM   #4
Rewards Points: 150
i'm no help just waiting to hear the problem
comp is offline   Reply With Quote
Old 07-31-2009, 09:51 AM   #5
Adding a bit more to this in case anyone has any advice. It seems like it goes through a normal defrost/cooling cycle, but the only thing is that the fan doesn't kick in until it's about 40 degrees in the freezer, then it kicks on and it cools to about 10 degrees or so as it should. I have no clue what would be causing that so any advice would be appreciated.
Old 07-31-2009, 02:15 PM   #6
596 cooling issue
I beleive,on that model of 596,the fan is controled by the defrost thermostat,terminator,or bimetal,whichever you want to call it.When you check the bimetal,my preference,see if it doesn't have 4 wires. Hope this helps. d scott
d scott is offline   Reply With Quote
Old 08-10-2009, 03:08 PM   #7
Kenmore 596
Our Kenmore 596 has the same issue. The repair man said that the evaporator being only partly frosted means that some of the coolant has leaked out of the system. Says it is an expensive repair that his company does not offer. Our condenser fan has always switched on and off and was actually stuck on a packing peanut. But after unsticking the fan, the freezer still does not get below freezing.
telepicker is offline   Reply With Quote
Old 08-22-2009, 08:00 AM   #8
the fan is delayed until that terminator closes. clear coils of any frost/ice. let it run for an hour or so, if the coils don't frost in their entirety you have a R leak..new refrig time. if they do show nice frost pattern all the way around- you have an erratic/out of limit terminator.
Jacques is offline   Reply With Quote
Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling redmachodevil HVAC 4 01-26-2011 03:21 AM
Kenmore ref. not cooling bloom42 HVAC 29 01-12-2010 05:14 PM
New Thermostat issues when cooling guimond777 HVAC 2 05-04-2009 10:46 AM
Kenmore fridge not cooling, freezer ok bobvanhalder Appliances 20 10-22-2008 11:36 PM
Kenmore fridge not cooling, freezer ok bobvanhalder HVAC 7 10-22-2008 10:52 PM
