Kenmore 400 Dryer - Appliances - DIY Chatroom Home Improvement Forum
Old 07-22-2013, 01:59 PM   #1
Kenmore 400 dryer
The dryer was purchased new in 2008 from Sears. I've never had an issue until this past month. The timer would reach the end of the cycle, but would not turn off. This was an issue that I thought I could live with, especially since all I had to do was just manually turn the dryer off after about 40 min of operation. It would dry the clothes just fine.
The issue that just surfaced last night is that the dryer no longer heats up or dries clothes. I ran it for 20 min, and there was no heat. I tapped the timer knob lightly and also giggled the dryer a bit, and to my surprise, the heating problem was solved. I think this was a temp fix, and was curious if anyone knew what the "non-heating" problem and timer issue could be?
Jay2013 is offline   Reply With Quote
Old 07-22-2013, 02:48 PM   #2
Rewards Points: 13,300
Need a full model number.
Old 07-22-2013, 04:11 PM   #3
The model number is 11069422800. It's a Kenmore Elite 400.
Old 07-22-2013, 04:25 PM   #4
Gymschu's Avatar
Rewards Points: 522
Could be any # of things. Kenmore used to be a quality name brand, but, like most others now, I'm sure it's made in China or the parts come from China. Believe it or not, your dryer is just about at the end of its life cycle. Five years is about what you get out of your appliances. It may be something as simple as a loose wire or a wire that had the insulation burned off of it and it's shorting out. It may be the heating element starting to go bad. Those are easy to replace and the parts are usually readily available. I know I have had Kenmore, Whirlpool, and several other brands in the recent past and they all lasted about 5 years before giving up the ghost.
Gymschu is online now   Reply With Quote
Old 07-22-2013, 05:18 PM   #5
Rewards Points: 6,652
Gymschu, depending on which Kenmore line, they are mostly Maytag appliances. The elite line is still made here in the U.S., by the company they use for that line.
Maytag are made mostly in Mexico.
As for the OP problem, most likely have had Brownout issues, or surges, which can cause these kind of issues, along with Neutral issues to the appliance or home, even if you are really not noticing, the electrical problems are still there.
Also how much they ise it, if te vent has been regularly cleaned out, overloading the machine cannplace undue wear & tear on the machine.
At this point, it is going to cost more to fix, then find a mom & pop shop that fixes and resell units, or just bite the bullet and get a Heavy Duty unit.
Stay away from HH Gregg or Best Buy Op. Lowe's, Home Depot you can usually find a decent deal on a scratch & dent, & usually can get the manager to come down even more, if you are regulars in there, or they just want to get it out of there.
Old 07-22-2013, 05:25 PM   #6
It works ok now, but the heat is still not at full throttle. I use the dryer at most 3 hours a week, which I feel is not that much. How do you check for continuity on the items that are designed to produce heat?
Old 07-22-2013, 05:59 PM   #7
Pull the dryer and check for Lint clog in the line. That is most likely why it is not drying as it should.
If you are getting heat, then the heating circuit is working.
Also take the back off the unit while you are at it, and clean out te large quantity of Lint in the dryer also.
Old 07-22-2013, 07:45 PM   #8
Rewards Points: 12
Jay, the dryer you have is made by Whirlpool. There should be a wiring schematic somewhere in the back of the dryer. It's probably behind the access for the control panel. I can't help with the continuity tests but the schematic should help. Since tapping the timer made it work, I'd speculate the timer needs to be replaced.
Dan
djlandkpl is offline   Reply With Quote
Old 07-22-2013, 08:26 PM   #9
Jay, check Repairclinic.com for pricing, but also check with the local mom & pop shop to see what their prices are on replacement parts.
Old 07-22-2013, 08:27 PM   #10
I was at work earlier when I posted. Could not remember Whirlpool for the other. Sears was odd and always has been on the different grades of tools and appliances who they use, which makes it fun to try and tell people which model to get, so they do not go with the cheaper line.
Old 07-22-2013, 10:47 PM   #11
chitownken's Avatar
Rewards Points: 510
If the model number starts with 110. it is a Whirlpool
chitownken is offline   Reply With Quote
Old 07-22-2013, 11:04 PM   #12
I removed the back of the dryer and discovered that one of the 4 heating element coils broke off and was resting at the bottom of the dryer. Do all coils need to work for the heater to produce heat??
Old 07-23-2013, 08:52 AM   #13
Why yes they do by George. You are placing more resistance on the one that is doing all of the work. Check with a local mom & pop like I stated before, and check the pricing at http://www.repairclinic.com. I have had good luck with everything that I have ordered from them, and even when the wife wanted the dishwasher handle fixed by two days, they had the order pulled that same evening, and on the plane to us, and in our hands next day. Of course the order was done by 5:30 pm.
Old 07-23-2013, 11:46 AM   #14
I checked for continuity at several different points and noticed that one of the points didn't pass the test. I'm not sure what this item is called (perhaps the cycling thermostat?), but in the below picture, it's the black item in the far left, with four wires (purple on the sides, and red on the top) connected to it. The two purple wires in the middle failed the test, while the wires on the top and bottom passed. What is this item called? Could this be the cause for the dryer not turning off once it nears the end of the cycle?
Old 07-23-2013, 12:16 PM   #15
Rewards Points: 12
I think it is the cycling thermostat. This is the part and there's a video on how to test it.
http://www.repairclinic.com/PartDeta...epairHelp=True
Dan
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 02:10 PM
kenmore 400 dryer no heat Mark77 Appliances 12 12-24-2014 06:04 PM
Kenmore Dryer Shuts Off Prematurely simeltzer Appliances 5 06-17-2013 06:53 PM
Kenmore Dryer Keeps burning up the fuse jones6826 Appliances 4 04-08-2013 09:21 PM
Noisy Kenmore Dryer Skeeter01a Appliances 2 02-22-2010 08:05 PM
