Kemore Fridg 106 Icemaker Door - Appliances - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 04:29 PM   #1
kemore fridg 106 icemaker door
The door on the front of the fridg freezer door is not sealing properly and ia forming frost inside do to the bad seal of the flapper door.
A small part fell out. I need to fix this but need some kind of diagram to take it apart. any suggestions are appreciated.
trimmantom is offline   Reply With Quote
Old 02-29-2012, 04:36 PM   #2
Rewards Points: 13,690
Get the whole model number and ser. #. Google appliance repair, look for a site called applaince clinic.
It has parts break downs, part sales and advice avalible.
trimmantom (03-04-2012)
Old 03-04-2012, 09:28 AM   #3
fridg door flap
Thanks Joe, I found a site maybe the one you're talking about with an expolded view of the area and parts. Took the trim plate off and found a broken pivot that the door flap hangs on. So I've got to order the whole plastic enclosure. Thanks again for your info also.
Old 03-05-2012, 07:45 AM   #4
That "enclosure" isn't avail as a separate part-go to local Whirlpool parts distb' and buy kit-#8201756. follow instructions with kit.
Jacques is offline   Reply With Quote
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 08:19 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 05:45 PM
1950s Bedroom Door Lock DeeJaye6 Carpentry 3 03-04-2009 12:09 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
