Jenn-Aire Range - Appliances - DIY Chatroom Home Improvement Forum
Old 01-27-2012, 03:38 AM   #1
Jenn-Aire Range
I'm getting an -FC- error message, and it won't stop beeping. At first the probe light came on (14 yr old range, probe never used), but it's off now, and getting -FC- message.
SleeplessHere is offline   Reply With Quote
Old 01-27-2012, 03:53 AM   #2
Jenn-Aire Range
Haven't done this before, so not sure how it works. Does someone respond at some point?
Old 01-27-2012, 04:18 AM   #3
Jenn-Aire Range
Helloooo?? Anyone?????
Old 01-27-2012, 06:43 AM   #4
Rewards Points: 31
It's a forum... You have to wait for somebody to come along that knows the answer. Might be a few hours or might be a day or three. Keep checking back. Reply to your own thread (bump it) only if no response after 24 hours or so.
Btw, wwlcome to DIY
ranger12 is offline   Reply With Quote
Old 01-27-2012, 07:58 AM   #5
That's a communication error code. may be or not from shorted probe receptacle. the only thing you can do is kill power for an hour, if fault returns, call local servicer who knows Jenn A'....always post model and serial # for best response.
Jacques is offline   Reply With Quote
Old 01-27-2012, 08:00 AM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
I'm going to assume that your FC code is actually F0 since fault codes are always F and then a #. Anyway F0 code would be a bad control board.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-27-2012, 12:54 PM   #7
Smile
Jenn-Aire Range
Thanks so much for your responses - where could I find the model and/or serial #? This unit is 14-15 yrs old, I can't find the manual. My dad had purchased it for me, and he's long since deceased. I'll try killing the power for an hour or more, and see if that helps.
Old 01-27-2012, 12:57 PM   #8
Smile
Jenn-Aire Range
Thanks for your responses. Where could I find the model and/or serial #? This unit is 14-15 yrs old, my dad purchased it for me and he's long since deceased. I'll try turning the power off for an hour or more and see if that helps.
Old 01-27-2012, 09:44 PM   #9
#1 HAWKEYE FAN
look behind the bottom door if it is a downdraft model.
Old 01-28-2012, 04:29 AM   #10
I thought it was F-0 also, but there is an FC code for J/A.
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
Drop in range versus self standing for narrow area sbrink Kitchen & Bath Remodeling 6 01-21-2011 10:17 AM
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 07:48 AM
Jenn Air Gas Range - One burner not sparking Dwizzo Appliances 13 09-22-2010 11:19 AM
Had a new electric range installed in my apartment - does this sound right? SAABturboDRIVR Electrical 15 01-02-2010 05:39 AM
