Jenn-Aire Downdraft - OEM Flex Duct Required? - Appliances - DIY Chatroom Home Improvement Forum
Old 10-09-2010, 04:35 PM   #1
Jenn-Aire Downdraft - OEM flex duct required?
I am repairing the flexible duct for my Jenn-Aire downdraft and was wondering if I needed to use the Jenn-Aire/Whirlpool brand flex duct or is generic sufficient? This is going from my Jenn-Aire freestanding oven/range downdraft to the downdraft motor. This is NOT from the motor to outside.
Here is the part I am referring to:
$35 plus shipping = Over $40 for a piece of flexible duct. Sorta pricey. The way my downdraft motor is mounted, there is ZERO slack in the flex duct between the range exhaust and the downdraft motor. And, apparently the duct previously torn and is not working as efficiently as it should be. Would be nice if I could use a different/slightly longer piece of flex duct but it appears to be a special type of metallic/black plastic coated flex duct so I want to make sure I don't run into trouble using generic.
Dwizzo is offline   Reply With Quote
AC Flex Duct - Suspend above attic insulation or lay it on top? fritzycat1 HVAC 13 08-17-2011 10:19 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 06:20 AM
flex duct termination issue LanterDan HVAC 2 02-12-2009 05:59 AM
Attaching Flex duct to register boot avshockey HVAC 15 12-03-2008 08:07 PM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 08:28 PM
