Jenn Air Sealed Burners Not Clicking Or Igniting - Appliances - DIY Chatroom Home Improvement Forum
Old 10-24-2013, 01:54 PM   #1
jenn air sealed burners not clicking or igniting
I have the ProStyle Jenn Air dual fuel downdraft range and cooktop. Suddenly one pair of the sealed burner cartridges stopped igniting. It is not clicking or igniting. When I interchange the pair of burners from the other side, they work there whereas the faulty pair does not click/ignite regardless of which side of the stove they are on. They will light with a lighter so the gas is not the issue.
Do you think it is the wires or could both of the ignitions be gone within the burner cartridges?
Any idea as to fix this without having to buy the entire cartridge?
Thanks Jo-Ann
Jo-Ann Eaton is offline   Reply With Quote
Old 10-24-2013, 08:18 PM   #2
Rewards Points: 214
Is it still under warantee by chance? I don't know if this will help, but there was an old thread on this forum about this topic awhile back, this person replaced just about everything on that range with no results, bottom line - it ended up being a loose wire not making contact. You can check out the link if you like and see if it helps. It may give you a few more ideas of what to check. Thanks.
jenn air burners not clicking or igniting
jmon is offline   Reply With Quote
2 back burners not igniting GRed Appliances 0 10-15-2013 09:27 AM
Furnace burners will shut off after 10 mins Liberator HVAC 10 01-20-2012 11:23 AM
Heil Gas pack: not all burners igniting cbaileyau HVAC 12 11-18-2010 06:56 AM
Gas Furnace Burners not Igniting!? drupason HVAC 23 10-21-2010 08:34 PM
American Standard Freedom 80 Furnace not igniting all 4 burners chetw66 HVAC 2 09-25-2009 06:01 PM
