Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-13-2013, 10:40 PM   #1
Jenn Air grease trap
The grease trap on my 15 year old Jenn air is clogged. The grease from cooking steaks stays in the bottom of the pan and doesn't go into the cup beside the oven. I ran the oven on a clean cycle thinking it would get the entire stove warm enough to unclog the lines. Although the grease in the cooktop turned to liquid, it never did flow down into the cup. Is there anything I can put down the lines, or am I going to need to replace the line to get it working again?
av-geek is offline   Reply With Quote
Old 01-13-2013, 11:42 PM   #2
STAFF
BigJim's Avatar
It has been a good while since I have done much with a Jenneair unit, can you raise the top up? Most of the units can be raised up to access the underside to work on the elements and things. You should be able to run something through the openings to unstop the grease.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 01-14-2013, 09:35 AM   #3
Just a guess.
Some Simple Green dropped into the hole with a turkey baster, let it sit, then clean with a test tube cleaning brush.
Old 01-15-2013, 03:55 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
that will be a hard task as that tube is kinda long and has a few turns in it. Best bet would be to get a stiff wire like a coat hanger and slowly work it down the tube if you can apply a little heat at the opening with a hair dryer or something it should help. Keep working at it and you should be able to get through it.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-16-2013, 07:59 PM   #5
Household Handyman
On my old Jenn-Air, circa 1986, was plastic. The tube on my newer unit, circa 2005, is also plastic. Both of these ran in a "curvy" pattern, so a coat hanger may not work. I also had the problem of these tubes getting stopped up on the old unit. I used very hot water, from a boiler on the stove, and a turkey baster to shoot the hot water into the tube until it cleared the tube out. After that I tried to remember (hah, hah) to keep these tubes cleaned out.
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 12:46 PM
PVC trap adapter on galvanized trap? dougan Plumbing 2 10-05-2012 07:16 AM
Grease trap requirements and codes Kim Scheu Plumbing 3 05-08-2012 09:58 PM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 08:59 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 01:39 PM
