Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-10-2011, 08:02 PM   #1
Jenn-Air gas cooktop
We have just purchased a home that has a Jenn-Air 4 burner gas cooktop. There is also a grill kit for the left side. The front right burner ignites perfectly. The other 3 burners do not click or lite and the back left burner knob will not turn at all.
kt2569 is offline   Reply With Quote
Old 12-10-2011, 08:27 PM   #2
Super Moderator
Sounds like a good cleaning of the burners and the electrodes might be in order---
As to the knob that's bad--call an appliance parts supplier and see if the part is available---
If the unit is old and tired you may need to replace it soon---Mike---
Old 12-12-2011, 06:21 AM   #3
If you plan on keeping this cooktop and have no skills on gas i would have a local servicer fix it. you need, at a minimum, a new valve for that stuck burner. don't think repair will be $ crazy and it will then be fixed and safe. call around with model & serial #'s. should be able to ballpark it for you.
Jacques is offline   Reply With Quote
Replacing kitchen cooktop. Devilsid Carpentry 7 09-08-2011 12:32 AM
Cooktop cut-out accuracy... jdrunbike Appliances 5 04-13-2011 11:46 PM
Electric Cooktop too slow to heat coachgns Appliances 1 02-05-2011 04:45 PM
Cooktop color? hgtv Interior Decorating 2 07-21-2010 12:49 AM
Jenn Air Glass Cooktop Jupe Blue Appliances 1 09-07-2009 12:18 AM
