-   -   janitorial (Goodman) Furnace won't ignite gas (http://www.diychatroom.com/f47/janitorial-goodman-furnace-wont-ignite-gas-188212/)
gabrielpanoussi 10-07-2013 05:49 PM
I purchased a used Janitorial (Goodman Furnace) Supposed to be natural gas gmnt080-4 90% 80,000 BTU.
I did not attempt to install until today almost a year later.
I have everything hooked up and it seems to work as it should it just does not ignite. Here is the process...
When I set the thermostat to heat...
1. a click then, a small exhaust fan turns on (this is the fan connected ti the PVC Exhaust)
2. a click then, the igniter receives power and glows red. Exhaust fan is still on.
3. a click then, the gas is released. at this point 15 seconds later the igniter dims and gas shuts off. IT repeats this 3 times and stops. The red LED on the control board of the furnace blinks till you power off or switch the thermostat to off.
When I select fan to on from auto...
1. Larger blower motor kicks on like it should.
Some things I tried,,,
The flexible gas line was rated at 60,000 BTU and was upgraded to a larger diameter line that supports 100,000+ BTU the furnace is 80,000 BTU.
What concerns me....
The 2 thin wires coming out of the gas control valve going nowhere (see pics once uploaded. Are they for AC?)
I can see the remnants of one of those yellow converted to propane stickers. It has been scratched off. Hoping it was converted to LP then back to NG.
I don't know if the fittings are the same on a LP furnace not sure it is physically possible to attach a NG line to something that is LP. So, I'm not sure about this theory.
Orifices I don't know what a natural gas one looks like but I know they matter. Could it have LP orifices? Is some thing else going on? There is a gas valve in place are those valves rated to a certain BTU rating limiting flow?
:censored: is going on? Thanks for the help winter is coming.
http://i1321.photobucket.com/albums/...ps2b601ce9.jpg
http://i1321.photobucket.com/albums/...psca8b4a00.jpg
http://i1321.photobucket.com/albums/...ps926fb03d.jpg
http://i1321.photobucket.com/albums/...psc320bce1.jpg
http://i1321.photobucket.com/albums/...psc84a06e8.jpg
http://i1321.photobucket.com/albums/...ps49d84e1c.jpg
http://i1321.photobucket.com/albums/...ps35578575.jpg
http://i1321.photobucket.com/albums/...pse8710dbc.jpg
gabrielpanoussi 10-07-2013 08:31 PM
OK problem or one of them is that this :censored:ing thing is propane. The guy who sold it lied. Orifice are stamped #55. I drove in the rain out to the country (should have been a clue) to pick this up.
So now I need new orifices and a spring.
I have trouble finding the correct orifice size for my model i think it is #43. Can anyone help?
ben's plumbing 10-07-2013 10:45 PM
best bet is to call johnstone supply they handle goodman..or check on line for the parts you need....welcome to buying used stuff... ben sr
plummen 10-08-2013 05:02 AM
They used to call themselves janitrol back in the day,I used to call them jani-junk back in the day before goodman bought them out and improved them greatly.
Im not sure if jonstone supply/j-mart will sell to the public in your area but its wort a try,you could check on line at ecomfort.com or someplace like that though.:)
gabrielpanoussi 10-20-2013 11:44 PM
Thank you all. I ended up ordering the gas valves and orifice from sears parts direct. They are supposed to be calibrated to the required water column.
I am in the next phase of my HVAC install and I have a question about the furnace condensate drain.
I have seen instances where the condensate drain is fitted to a T that connects to a 3" primary vent, is this necessary? I assume this is done because it is a mixture of gases and liquid. Am I correct? A trap is also required in the drain line to prevent exhaust gasses escaping. Correct?
Thanks all just want to know what I am dealing with CO2 kills.
collegetry 10-21-2013 08:14 AM
Janitrol not Janitorial
gabrielpanoussi 10-21-2013 03:42 PM
ok Janitrol then.. lol. Thanks! :thumbsup:
