Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-26-2009, 11:11 PM   #1
Default I've got A Roper RT185DKXKQ00 which cools great
I've got A Roper RT185DKXKQ00 which cools great but when it cycles on you can hear what sounds like either the fan or compressor laboring. It eventually stops making this sound but the whole time it happening you can hear loud static coming through the TV and Stereo speakers, touch lighting in our dining room flickers on, and I lose internet access for several minutes. I thought it may have been the incoming power so we had the power company replace the transformer. It does this regardless of house temperature or time of day. Any suggestions?
Potastew is offline   Reply With Quote
Old 10-27-2009, 09:11 PM   #2
I would check the start relay. Hope this helps
d scott is offline   Reply With Quote
Old 10-27-2009, 10:15 PM   #3
That was my first thought but don't have any drawings on it and can't determine where exactly the start relay is. I'm guessing it's the small plastic box attached to the compressor. Does that sound right to you? There's nothing that is up inside of the frige that I need to empty everything out is there?
Old 10-28-2009, 11:30 PM   #4
clicked on wrong thread
CustomBuild is offline   Reply With Quote
Old 10-31-2009, 05:11 PM   #5
I think I figured it out. I pulled the fridge out inn order to monitor the problem and it hasn't done it since. Now that I have adiquit airflow I can only assume it was getting too hot due to lack of airflow so the thermal overload (if this fridge has one) was on the edge of from tripping. There is a white box on the side of the compressor that I think is the cause of this problem but I don't have a spec sheet to break down what it is. Thanks for the suggestiosns
More On This Topic
So now we're going to talk a little bit more about what the compressor and what the reverb moduals actually do. The compressor that I assigned to the return one is a sound modual that basically compresses the individual sound that you have assigned to... Read More »
Hi, my name is Gary Schutt. We’re talking about guitar effects, right now it’s an effect called the compressor. Compressors can be used for such things such as vocals, drums, base, but right now we’re going to be talking about it for... Read More »
Alright for our next compressor we're going to be looking at the Opto Compressor. The Opto Compressor is more like a warmer type compressor. It kind of reminds people of an analog compressor. So, what we are going to do is we are going to look right here... Read More »
This is Larin Parker with Expert Village! I'm going to talk to you a little bit about diagnosing problems with your audio gear just by listening. Here I have a nineteen sixties Fender Rhodes piano and it's currently not working. One problem though, we... Read More »
When your battery needs changing, it will depend a little bit on the hearing aid, but there will be some warning signs that your battery needs changing. With many of the digital hearing aids you'll start to hear a little bit of a static in the sound of... Read More »
Great room/Man Cave Must haves Scuba_Dave General Discussion 5 08-09-2009 12:10 AM
Great Find hankscorpio Tools 2 04-20-2009 12:40 PM
Great Stuff question amakarevic Building & Construction 14 01-02-2008 12:28 PM
foam like Great Stuff that is waterproof amakarevic Building & Construction 1 12-30-2007 10:52 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
