| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Buy a Range Hood
by eHow.com
Creating delicious meals for the family at home also creates tantalizing aromas in the air. However, you need proper air ventilation to remove odors from grease, smoke and moisture. Whether you're redoing your kitchen or building a new home, several... Read More »
How to Clean a Range Hood Filter
by Ann Myrick
A range hood filter can get very dirty with grease and grime build-up, and soaking it helps to loosen this build up. Clean a range hood filter in the sink with soapy warm water and detergent using tips from an experienced housekeeper in this free video... Read More »
How to Pick a Built-In Smoker
by eHow.com
For someone who barbecues often or merely enjoys the smoked taste of meat, a built-in smoker is a dream come true. As an addition to an outdoor kitchen, the built-in smoker doesn't take up as much room as it would if it were not built-in. But the final... Read More »
DIY Soundproofing
by Arthur Noxon
In DIY soundproofing, sheet rock needs to cover any windows. Soundproof a room personally with tips from an acoustics specialist in this free video on soundproofing. Read More »
How to Buy a Kitchen Fan
by eHow.com
The kitchen is usually the hottest room in a home. Due to the heat generated by stovetops, ovens and toasters, most kitchens are equipped with exhaust fans. These small, but powerful, fans are usually located inside a hood just above a stovetop. Hot air... Read More »
