Intake Gas Pipe With Holes For Gas Grill, - Appliances - DIY Chatroom Home Improvement Forum
Old 02-19-2011, 03:40 PM   #1
Intake Gas Pipe with holes for gas grill,
I have a outdoor gas grill over 12 yrs old and do not know manufacturer. During cleanup, I found it all rusted and in the process, I broke it. I need to replace it. It is approximately 16'' long and it fits on one side to gas (a built in tap). There are two parallel pipes to be covered by fake coal to spread the heat evenly. I need your help to select the appropriate pipe and buy it. Thanks.
RD Dhekne is offline   Reply With Quote
Old 02-20-2011, 06:40 PM   #2
I'd suggest you go to the nearest gas bbq/fireplace store, not big box. Explain what you're looking for, bring some pics, and they should be able to help you.
VIPlumber is offline   Reply With Quote
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 04:51 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 10:49 PM
making holes in the joists to run pipe christy123 Plumbing 5 01-20-2007 04:05 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
