Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 04-19-2012, 06:17 PM   #1
Installing Vent Hood, What to Expect?
I want install my range hood and vent it on the backside and out to the side of the house.
I have a house from the mid 70's with brick siding.
What's the proper way of doing this? How to seal everything up after the hole is cut to keep water and the weather out?
My plan right now is the put the new vent hood in place and mark the 4 corners of the vent duct.
Drill holes from the inside to outside.
Go outside and drill as many holes as I can between the four points and then chisel out the brick once I have made a perforated border with a 1/2 drill bit.
Does that sound about right?
Don't know how to seal everything back up yet but I am open to ideas.
kingofmycastle is offline   Reply With Quote
Old 04-19-2012, 07:14 PM   #2
A "Handy Husband"
rjniles's Avatar
Be prepared to deal with a stud right in the middle of the opening in the wall.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following 2 Users Say Thank You to rjniles For This Useful Post:
oh'mike (04-19-2012), Tom Struble (04-23-2012)
Old 04-19-2012, 07:52 PM   #3
I already checked that, I am in the clear for that.
Old 04-22-2012, 03:22 PM   #4
Anyone has anymore tips about how to cut a opening in my brick siding and how to seal it back up when the duct is installed?
Old 04-22-2012, 07:13 PM   #5
So I removed the existing range hood and found vapour barrier and batt insulation behind the drywall. What should I do to seal the vapour barrier when I am done? Seems impossible.
Old 04-23-2012, 12:43 AM   #6
Cool
I removed the old hood fan. i found a duct 6 x 2 in the wall. it goes outside. is there something to put in this to direct the exhaust in the right direction? the 6 x 2 goes up to the ceiling. the sheet rock has seen better days. the power wire is justing hanging. do i need to put this in a junction box?
byronksd is offline   Reply With Quote
Old 04-23-2012, 07:33 AM   #7
Stay-at-home GC
Not sure about the duct.
If there is enough slack to bring the wiring into the vent hood and make your wiring connections in there then you don't need a junction box.
If not you'll have to junction and leave it accessible or back it out to the last junction box and pull new wire.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Installing a gable vent..from *inside* the attic steveKane Building & Construction 8 12-09-2012 03:45 PM
Is it common for roofers to NOT slice underlayment on a ridge vent before installing? jcarlan Roofing/Siding 29 01-05-2012 04:26 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
Hood / Vent Requirements for Gas Stove WaldenL HVAC 1 09-09-2009 04:38 PM
can I 'patch in' a bathroom vent into my kitchen's stove hood vent? joeyboy HVAC 2 09-10-2007 01:36 PM
