Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-02-2010, 10:31 AM   #1
Installing new over the range microwave
Greetings,
I have removed an old over the range microwave and purchased a new one. The mounting brackets on the wall from the old one are different than the new one. I am trying to find out if I need to remove the entire brackets from the old one? I have a few pictures. The new one has no directions so I am a little lost. Thank you all for your help!!
Installing new over the range microwave-old-mount.jpg   Installing new over the range microwave-new-microwave.jpg
islic is offline   Reply With Quote
Old 05-02-2010, 05:25 PM   #2
A "Handy Husband"
rjniles's Avatar
You should be able to go to the manufacturers web site and down load the instruction/owners manual.
I would change the bracket, the most you are looking at is half a dozen screws.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 05-02-2010, 06:51 PM   #3
Super Moderator
You need to change the bracket.----That one mounts 14 1/2 down from the bottom of the cabinet to the top of the bracket.(check my numbers ,please.I installed that very unit yesterday.)
Make sure to drill the hanging screw holes into the cabinet above--use a 1/2 inch bit.
The blower comes from the factory set to blow out the front of the unit(into the room.)
If you have a top or back duct ---open up the plate over the blower---3 screws--
simply lift up the plastic blower and rotate it to blow out of the top or back--put the screws back.
Slide in the damper piece.
That's it--Go hang that thing!----Mike---
Old 05-03-2010, 07:39 AM   #4
Also, if you bought that m/o as new- there's no way it didn't come with instructions. it made a stop along the way. more and more common these days.
Jacques is offline   Reply With Quote
Installing Range Hood and Stainless Steel Backsplash oguevarra Remodeling 1 02-26-2010 05:01 PM
HELP. I really need some advice on how to remove an over the range microwave! justmeee Appliances 9 12-24-2009 04:47 AM
Installing a range hood NewHandyman Electrical 1 08-10-2009 10:42 AM
Installing New Gas Range. larlombar Appliances 2 05-17-2009 06:28 PM
Installing over the range microwave ex-Khobar Andy Electrical 1 02-06-2009 04:20 AM
