Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-18-2006, 03:10 PM   #1
Installing a gas range (advice needed)
I'm installing a new gas range. Is there anything I need to know before connecting the new one and turning on the gas for the first time in 5 months? Thanks!
Krichton is offline   Reply With Quote
Old 11-18-2006, 06:53 PM   #2
Handyman
Is this a countertop range?
canadaclub is offline   Reply With Quote
Old 11-18-2006, 09:51 PM   #3
No freestanding.
Old 11-18-2006, 10:19 PM   #4
test your fittings with soappy water rinse and find a match
ncor is offline   Reply With Quote
Old 11-18-2006, 11:19 PM   #5
jeff1's Avatar
Hi,
This may help....
http://www.applianceaid.com/gasconnector.html
jeff.
Appliance Repair Aid
JRAppliance
jeff1 is offline   Reply With Quote
Old 11-19-2006, 08:54 AM   #6
NothingsLevel's Avatar
It's really easy - I did it myself last winter for the first time. If you've ever hooked up a gas clothes dryer, it's the exact same deal.
Get the kit which comes with the gas line, fittings, sealant and soapy water "test fluid" all in one bag. Follow the printed directions and as long as you know which end of a wrench to hold, you should be done in under 30 minutes.
NothingsLevel is offline   Reply With Quote
Old 11-20-2006, 02:35 AM   #7
Thanks for all the replies. I was actually concerned more about the gas than anything else. Now that I finally got around to connecting everything I just discovered that the nipple still attached to the gas pipe is too small to be connected to the standard gas supply line that came with the range. Damn that thing is tight!!
Old 11-23-2006, 01:27 PM   #8
jeff1's Avatar
Sometimes a little penetrating oil soaked in helps.
jeff.
JRAppliance
Old 11-24-2006, 09:20 PM   #9
The good thing is, if you screw it up you'll smell it pretty quick... Just make sure your "off" valve works well!
I used teflon tape on my threads when I attached my range. Make sure you use it only on the threads, and not on the surfaces where the nipple joins.
Hushpuppy is offline   Reply With Quote
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
Installing New Gas Range TonyD Plumbing 2 04-08-2007 02:41 PM
Painted deck - advice needed! Sallie Painting 5 03-23-2007 12:03 AM
Urgent advice needed on sagging roof for home I'm buying jwoair23 Roofing 6 02-20-2007 12:17 PM
bathroom floor tile job advice needed dbrew Flooring 14 01-23-2007 08:03 PM
