Installing Gas Range - Appliances - DIY Chatroom Home Improvement Forum
Old 01-06-2008, 09:01 PM   #1
Hi, what's the clearance on the sides of a gas range to the side cabinets? Thanks
helpless handyman is offline   Reply With Quote
Old 01-06-2008, 11:39 PM   #2
Custom Cabinet Maker
usually close to zero. They are designed to slip into a 30" opening and are very well insulated to keep heat in so are almost cold on the outside when on
skymaster is offline   Reply With Quote
Old 01-07-2008, 12:05 AM   #3
yummy mummy's Avatar
Rewards Points: 1,016
Jackie
You are absolutely correct. I have a gas range and it is about 1/8 of an inch, (maybe even less) away from the cabinet and does not get hot at all.
Jackie, you are one smart cookie.
yummy mummy is offline   Reply With Quote
Old 01-07-2008, 08:44 AM   #4
Post
Thanks Skymaster, and we can't forget Yummy Mummy I want to install it as close as possible, wifey doesn't like crevices between the stove and counter top. Thanks
Old 01-07-2008, 03:43 PM   #5
YUmmy: thanks however you are SO MUCH CUTER LOL
gas range swap kenny11876 Appliances 2 02-20-2008 09:31 PM
Drop In Range Hook-Up mickey45 Electrical 1 04-08-2007 10:29 PM
Installing New Gas Range TonyD Plumbing 2 04-08-2007 02:41 PM
Installing a gas range (advice needed) Krichton Appliances 8 11-24-2006 09:20 PM
Replacing Stove Top with Range the.vicster Electrical 3 02-23-2006 06:12 PM
