Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 08-02-2010, 04:22 AM   #1
installation of Schneider XUM model photo-electric sensor
How to insatll a Schneider XUM model Photoelectric sensor in a hydraulic system.
when the pump works any movement near the hydraulic bench should cut the power and accordingly pump should stop.
any relay is required in between the sensor and the motor mains?
Jayakumar is offline   Reply With Quote
Old 08-05-2010, 06:27 AM   #2
SemicentenarianTroglodyte
CaveDave's Avatar
Location: 10 miles south of Buddy Holly's hometown (Lubbock, Texas), with unlimited view of flat, brown, dirt.
A few questions first:
1) What is a "hydraulic bench"? Is it a press or similar?
2) When you say "how to [install] in a hydraulic system", do you mean the mechanical (physical) mounting and placement, or the electrical interfacing?
3) What are the nameplate ratings of the pump motor, and what is the existing control arrangement? (a wiring diagram would help).
4) Do you already have a particular unit selected, or do you just want to select a suitable part number from that product line? (there are many different choices in the XUM line)
5) Is this a life-safety application that must meet industrial codes? i.e. is killing the motor sufficient, or are pressure dump or blocking valves needed, also?
Photos of your application would make things easier.
A product line bulletin for the XUM series is here (PDF file).
Provisional answers:
a) The XUM series appears to require 12-24 volt DC power and only control 100 milliamperes or less, so a power supply and at least one relay will likely be needed.
b) Unless one is already in place, a magnetic motor starter or definite purpose contactor will probably be needed.
Please let me know more info.
HTH
Cheers,
Dave
CaveDave is offline   Reply With Quote
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 03:01 PM
Ruud furnace issue on upgrade board and flame sensor rubberman HVAC 22 01-16-2010 12:34 AM
changing old 1800 model stove from electric to gas Rangerwife731 Appliances 2 09-23-2009 08:58 PM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 11:27 AM
Honeywell Electric Thermostat Model T498 staylori HVAC 1 01-14-2006 01:25 PM
