Install New 36" Stanless Steel Gas Range Into 40" Space - Appliances - DIY Chatroom Home Improvement Forum
Old 03-19-2013, 05:31 PM   #1
Install new 36" stanless steel gas range into 40" space
I had an old electric range installed in a 40" space. To replace with a gas range, I found out that there are not many choices, but for the 36", a lot. Any one know how to fill up the 4" gap if I get a 36" range? The range is stainless steel and counter top is granite.
lti2000 is offline   Reply With Quote
Old 03-19-2013, 06:59 PM   #2
you could add fillers on the cabinets and if you can still buy the granite have pieces made to fill in the counter. they might even have some scraps in the color you need.
Old 03-19-2013, 07:03 PM   #3
Rewards Points: 13,724
A whole lot less work and money to keep looking find another 40".
Trying to "fix" that counter top and not have it show is going to be the big issue.
Old 03-19-2013, 07:45 PM   #4
Thank you. I will see if they have something close to my current counter top. It has been 8 years since I installed it. Option to buy 40" is first option but the type and brand I like does not come many.
Old 03-19-2013, 08:52 PM   #5
I'm in the same situation but I bought a 30" range to replace my 40" range. The problem is they don't make them with pot storage any more. Closest I've seen was baking pan storage. I still don't know what I'll do, but the kitchen cabinets are old so maybe I'll get new ones with a modern sized space for an oven eventually. Meanwhile I keep a garbage can in the space, and I've thought about putting a heat resistant shelf above it. I was also thinking of widening the little wall that's next to 9" gap.
Dorado is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
over range microwave smaller than space Joellen Appliances 2 02-24-2011 07:24 AM
Drop in range versus self standing for narrow area sbrink Kitchen & Bath Remodeling 6 01-21-2011 10:17 AM
Range hood and microwave shelf install??? osueric27 HVAC 2 01-05-2009 12:01 AM
How much space do I need to install a 5'6" bathtub? slatergrl Plumbing 6 02-05-2008 09:28 AM
