Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-18-2011, 11:43 AM   #16
InSinkerator issue
Originally Posted by jfrotten
<img src="http://www.diychatroom.com/attachment.php?attachmentid=42726"/>
I just try using the end of a small hammer which is wooden and it almost busted should I try something with metal
dinosaur1 is offline   Reply With Quote
Old 12-18-2011, 12:01 PM   #17
InSinkerator issue
I turned the electricity back on. I still hear the hum sound. I tried pouring water from the sink but whenever I do that the circuit breaker for the disposal turns off every time and the smell that I am getting from the disposal is when something is shot. I tried pressing the red reset button but now it's stuck and I can't get if to come back out.
There is some buildup around the red button.
Old 12-18-2011, 12:06 PM   #18
InSinkerator issue
Right now when I touch it on the bottom and sides it's very hot.
Old 12-18-2011, 12:58 PM   #19
InSinkerator issue
definitely either seized, or the motor has failed.
either get it unstuck using the methods already posted, or replace the unit
Techy is offline   Reply With Quote
Old 12-18-2011, 01:18 PM   #20
InSinkerator issue
Im just gonna replace it. This smells like its shot
Old 12-18-2011, 01:41 PM   #21
InSinkerator issue
I already told you what i would do. Metal to metal with a tap will deliver more tap to the shaft . than that metal to wood ?? This unit is a motor now it has bushing or beiring's on the shaft so wouldn't a tap on both ends maybe move it ?? What do you have to loose ? if it is that tight than my thought's above would be what i would do . But it is your's good luck
del schisler is offline   Reply With Quote
Old 12-18-2011, 04:27 PM   #22
InSinkerator issue
Could I buy a different type of garbage disposal. Now I have a InSinkerator 3/4 Emerson e404. I really like the waste king model 3/4 3300.
Old 12-18-2011, 07:47 PM   #23
InSinkerator issue
Anyone know what this is? I found it on the floor after taking my new disposal out of the box.
Old 12-18-2011, 07:48 PM   #24
InSinkerator issue
Kenmore, works great!
Old 12-18-2011, 07:57 PM   #25
InSinkerator issue
Attachment 42751
looks like 3/8 compression ferrell
The Following User Says Thank You to ben's plumbing For This Useful Post:
del schisler (12-18-2011)
Old 12-18-2011, 08:07 PM   #26
InSinkerator issue
Which goes where and does what..?
Old 12-18-2011, 08:10 PM   #27
InSinkerator issue
I also had a dishwasher recently installed...could it be for that?
Old 12-18-2011, 08:11 PM   #28
InSinkerator issue
has nothing to do with your disposal....it is used on water supply lines....not sure why it was in your box.....dosen't belong there....
Old 12-18-2011, 08:12 PM   #29
InSinkerator issue
yes could have been for the water line to d.w
Old 12-18-2011, 08:13 PM   #30
InSinkerator issue
Should I be concerned. I bought a dishwasher kit but had someone assist me in installing the dishwasher.
