Inglis Fridge Isn't Cold Inside - Appliances - DIY Chatroom Home Improvement Forum
Old 10-19-2011, 08:44 PM   #1
inglis fridge isn't cold inside
We have an older Inglis fridge...top freezer works great. Over the last while we noticed the fridge becoming less cold, now its almost not cooling and we took everything out. With that there has increasingly been water pooling on the bottom of the fridge, enough to keep a towel on the inside to soak it up. Where do I start to find a fix - Thanks in advance.
wendl is offline   Reply With Quote
Old 10-20-2011, 07:58 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
check the evap coil in the freezer, it may be frosted over. If so you have a defrost problem and need to find the defective part.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
now outside, cold inside kirkbarrow.gara HVAC 12 12-13-2010 06:24 AM
Freezer not cold enough at "normal" setting... skipjack Appliances 2 02-01-2010 03:10 PM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 04:47 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
how cold is too cold for vinyl siding? THEBIGPUNN Building & Construction 1 11-22-2005 10:50 PM
