Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 03-21-2013, 06:57 PM   #1
Infrared heater shuts off
Got one of these infra heaters. 6 element. When I have the thing on either high or low, it shuts off completely sometimes.......then power comes back on in about a minute or two. Seems to be some sort of overheat protection deal. I also noticed that while it sits in the off position, with power to it, there is some slight amount of heat still coming out. Anything I can do to repair it myself or are these things just throw aways. Thanks.
gmbwrenchn is offline   Reply With Quote
Old 03-21-2013, 07:00 PM   #2
No model #, No make, no picure or web site?
Is this something you just bought?
Why not contact the manufacture?
Old 03-21-2013, 07:16 PM   #3
Was going to contact MFG. Thought it could MAYBE be a easy fix.
http://www.ebay.com/itm/390365206161...84.m1423.l2648
Old 03-22-2013, 08:16 AM   #4
From what I can see there is a filter and a blower motor in this unit. Have you opened it up to clean it? One thing about these small heaters is they are great vacuum cleaners as well. They suck in all kinds of dust and clog the filters.
danpik is offline   Reply With Quote
Old 03-22-2013, 05:36 PM   #5
Yea I cleaned it all out and the same thing still happens.
Turning off hot water to fix 1/2 inch CPVC pipe in crawl space steve3847 Plumbing 21 12-20-2012 02:53 AM
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 03:54 PM
Space Heater in Hot Water Heater Closet? MsMojoRisin Plumbing 0 02-09-2011 01:50 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Propane water heater shuts off jcross HVAC 1 03-19-2009 09:21 PM
