Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-07-2009, 06:54 PM   #1
Default Ignition Problem with KitchenAid Gas Range
I have a KitchenAid gas range that came with my house when I purchased it about a year ago. Recently the oven is having trouble lighting. You can hear the ignitor "sparking" three or four times, but the oven burner doesnt catch. The oven will wait about a minute and try again. Some times the oven will light on the first try; sometimes it will light on the second, third, or forth cycle; and other times we have to use a BBQ lighter to get it started. Once the oven is on, it seems to have less of a problem re-lighting to stay at temperature. Is this a faulty igniter or another part?
The model number is KGSA906PBTOO. The part list can be found at http://www.appliancepartspros.com/pa...del_id=5152140 but I can only see the ignitor for the broiler in those diagrams.
Any suggestions would be appreciated. Thanks.
Michael
dataflux is offline   Reply With Quote
Old 11-07-2009, 09:05 PM   #2
Residential Contractor
Sometimes ranges will not work properly if the polarity of the outlet is reversed. Since you indicated that it started recently, that probably isn't it but it's at least worth a look.
rselectric1 is offline   Reply With Quote
Old 11-07-2009, 10:01 PM   #3
Whats the best way to ensure the proper polarity? Does it come down to the orientation of the plug into the electrical outlet?
Old 11-07-2009, 11:50 PM   #4
The easiest way is to buy a tester that plugs into the wall and different lights mean different things. (Sorry I don't know the correct name off-hand of this tester but the cheapest ones are yellow, have blades that will plug into the outlet and have three lights)
If you only have a voltage tester, see if you have 120 volts between the smaller slot on the receptacle and a ground. (if your house has romex, the ground would be the bare wires in the box-If you have conduit and metal boxes they will, or at least should be grounded)
If that checks out, your polarity should be ok but if you get 120 volts across the larger slot and ground, your polarity is reversed.
Old 11-08-2009, 07:01 AM   #5
this is a complicated system, but i think in your case [if polarity is ok] the pilot holes on burner are blocked[carbon buildup ?] it's not sensing flame so it will keep trying until it locks out. if was other problems it would continue to spark when you self light it...also check alignment of igniter to burner.
Jacques is offline   Reply With Quote
More On This Topic
How to Use a Plug Tester
How to Use a Plug Tester by Expert Village
This is a plug tester, these lights light up when there's power to the plug. It tells you what the problem is if there's a problem. It shows you what's correct, they have a little code on there a little legend and it'll tell you if the hot and ground are... Read More »
Hi! This is John from expertvillage.com. In this video clip, I will be discussing the electrical requirements for chop saws. This particular saw is wired at the factory for a standard 120 volt connection. You want to connect it to a 120 volt, 15 amp time... Read More »
Hi! This is Jon on behalf of expertvillage.com. In this video clip I’ll be talking about electrical safety. You’ll notice that on our planer the plug does have three prongs. This third prong is essential in properly grounding your planer. If... Read More »
Working with electricity in your home can be tricky at best. Remember to unplug appliances and trip circuit breakers to outlets and switches to work with electricity safely. Use electrical gloves and safety glasses at all times. When testing an outlet or... Read More »
I'm Mark Blocker on behalf of Expert Village. The automotive electrical system primarily for the last 25, 30 years, is based off of 12 volt battery. Some vehicles, diesels, and trucks would use 2 of these 12 volt batteries requiring extra power. The 12... Read More »
furnace ignition troubleshooting buju HVAC 22 01-15-2009 12:41 AM
Gas Range cookiemom1970 Plumbing 1 11-14-2008 06:58 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 08:26 PM
Electronic ignition question on propane range bearann Appliances 1 05-18-2008 11:11 AM
carrier 58SX ignition problem typhoon55 HVAC 5 06-08-2005 11:18 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
