If My Dryer Starts To Have A Major Or Worse Fire What Do I Do? - Appliances - DIY Chatroom Home Improvement Forum
Old 11-13-2007, 07:25 PM   #1
Question
If my dryer starts to have a major or worse fire what do I do?
Should I try to put out the flame myself?
Fira is offline   Reply With Quote
Old 11-13-2007, 07:56 PM   #2
I would, but if after about 10 seconds, if the fire isn't getting smaller, get yourself and family out of there and call 911
send_it_all is offline   Reply With Quote
Old 11-13-2007, 07:57 PM   #3
Cool
Thank you so extremely much! I do extremely appreciate that you helped me
Old 11-13-2007, 08:49 PM   #4
Dryer fires are often caused by not cleaning out the vent line, so start by making sure that's clear.
Then if you happen to have a fire, you can discharge an extinguisher into the dryer, but make sure you've got you've got a safe way out, and you are always between the fire and the door. Even if you get it out, call the FD immediately because a dryer fire can continue to burn inside your vent line, and inside your wall.
NateHanson is offline   Reply With Quote
Old 11-13-2007, 08:57 PM   #5
Firefighter/Paramedic
tyler101's Avatar
Just beware that most dryer fires start toward the back of the dryer unit. This is the place where electricity and sometimes gas enters the appliance. Flames may burn through the insulation on the wires causing another hazard. Don't be afraid to call the fire deparment after you may have extinguished the fire. We have camera's that can see heat inside walls if any exists.
tyler101 is offline   Reply With Quote
Old 11-13-2007, 10:03 PM   #6
Maybe you would try to extinguish it first, but yes by all means call 911. And don't bother trying to get your clothes out.
XSleeper is offline   Reply With Quote
Old 11-13-2007, 11:32 PM   #7
just want to share on how to prevent your dryer from catching fire...wash the lint filter with hot soapy water and brush once every six months.
and you may also keep an eye on the dryer duct. you need to disconnect, clean and inspect the dryer duct on regular basis or you may hire a professional to clean out the dryer duct.
in this way, you will reduce fire hazard, increase dryer's efficiency and lifespan.
good luck and be safe.
Kitchen sinks is offline   Reply With Quote
Old 11-15-2007, 02:19 PM   #8
Rewards Points: 5,336
Access to the flame will be the determining factor. If the unit is buried in a tight spot, how are you going to get to the area where the flame is?
Call 911 first, then while they're on the way you can make an attempt on putting it out or at least slowing it down.
Your success will depend on how capable you are and the equipment you have at hand.
As stated before, better to avoid the issue with proper maintenance.
Ron
Old 11-17-2007, 01:02 PM   #9
Rewards Points: 150
Fira,
You're kinda like what Sir Charles Barkley says"...." You made my top 5..."
JGarth is offline   Reply With Quote
Old 11-18-2007, 09:33 PM   #10
Rewards Points: 378
Define "small" as opposed to "large" fire.
fireguy is offline   Reply With Quote
Old 01-22-2008, 09:55 PM   #11
weekend warrior
Rewards Points: 150
Hopefully they didn't post as the fire was happening
to answer your question, it depends. is your home owners insurance upto date? and how bad do you want a new house?
johnny331 is offline   Reply With Quote
Old 01-23-2008, 12:02 PM   #12
Make sure that you clean the dryer lint screen after ever load of clothes no matter how little lint is on the screen.
If you are using plastic venting, get rid of it, it is nothing but a fire hazard.
With metal vent the fire will stay contain.
The dryer should be vacuumed out at least once a year.
You should have a fire extinguisher in the laundry room or area and you should also learn how to use it.
But by maintaining your dryer the chances of a fire are next to none.
If you find that you need a new lint screen or other parts here is a good place to get appliance parts.
girltech is offline   Reply With Quote
Old 01-23-2008, 09:19 PM   #13
yummy mummy's Avatar
Rewards Points: 1,016
Originally Posted by JGarth View Post
Fira,
yummy mummy is offline   Reply With Quote
Old 01-23-2008, 09:23 PM   #14
Old 01-23-2008, 11:19 PM   #15
Rewards Points: 530
Dryer on the fritz.. wiring problem? cisco10 Electrical 17 11-19-2009 01:26 PM
dryer woes... cisco10 Appliances 3 09-02-2007 03:46 PM
Problem with ELECTRIC DRYER plugs SpaceCrawler Appliances 6 06-03-2007 10:21 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
