Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-30-2013, 09:25 PM   #1
Ideas on small laundry closet??
Hello,
I have a "small" problem. We are looking to replace our washer dryer, but are limited by closet space. The closet is plenty wide 65 1/2" wide, but it is only 30 1/4" deep from inside of the bi fold doors to the wall. Front loads are pretty much out of the question as they are usually 32" plus deep. I have moved the doors out to the front edge of the jamb to get the 30 1/4" depth. The back wall is adjacent to a bathroom, so I can't move the wall back. I have thought of extending the jamb out an inch to get 31 1/4" depth, which I can find a dryer to fit. I have also thought of using a side exhaust for the gas dryer to allow the dryer to fit all the way against the back wall. Any ideas??
norm58 is offline   Reply With Quote
Old 01-30-2013, 10:24 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
side venting is likely to be your only option
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-30-2013, 11:36 PM   #3
is there any room to sides of the door way, as in wings to either side of the door way?
redman88 is offline   Reply With Quote
Old 01-31-2013, 07:30 AM   #4
custom user
You asked for ideas so here's one. Leave the doors off and give the area a nice finished look.
JasperST is offline   Reply With Quote
Old 01-31-2013, 08:37 AM   #5
I do have room on the sides. The closet is an entry way out of the garage, as you know 99% of the guest use, so I need to ba able to close it up.
Old 01-31-2013, 10:38 AM   #6
could you use top load washer and dry and turn them 90deg and slide them into the wings of the closet?
Old 01-31-2013, 10:53 AM   #7
I have thought about that also, but you don't see many top load dryers. The inside dimensions of the closet are 65 1/2" wide and 30 1/4" deep to inside of doors.My current washer is 27" wide and dryer is 29" wide...tight fit! Thanks for the great ideas...
Old 01-31-2013, 12:46 PM   #8
Take a picture of the area would be helpful.
Just throwing some ideas and seeing what might stick
  • If there's enough room, you could build out the closet opening by an inch or two to allow the doors to fit if you need doors.
  • Or keep them front facing and build in a nice louvered "built-in" for them. It may stick out slightly, but if you want front load, that seems to be the only option then.
  • How wide are the washer and dryer? You could stack them and have them sideways. Might be a tight fit, but potentially doable?
dengle is offline   Reply With Quote
Old 01-31-2013, 12:54 PM   #9
http://www.google.com/search?q=top+l...hrome&ie=UTF-8
Old 02-01-2013, 10:00 AM   #10
Here are two pictures of the area
Ideas on small laundry closet??-laundry1.jpg   Ideas on small laundry closet??-laundry2.jpg
Old 02-01-2013, 11:34 AM   #11
yeah looks like to me you need to bring the wall forward.
Everything Zen need some ideas thunderseed Interior Decorating 6 07-07-2012 04:59 AM
Removing existing closet gnomonklater Building & Construction 4 12-02-2011 01:14 AM
Closet Reno Ideas? AIMRob Remodeling 0 08-10-2010 10:11 AM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 02:37 PM
Condo with tiny backyard. Looking for low budget (small) patio ideas kalagal Landscaping & Lawn Care 1 04-08-2009 08:58 AM
