Icemaker Leaks - Appliances - DIY Chatroom Home Improvement Forum
Old 02-10-2008, 11:16 AM   #1
Question
Icemaker leaks
Frigidare side by side ice maker leaks internally large icesickle eventually solidifying ice bucket. Have checked levels, removed maker and checked for leaks, have run out of ideas. Makes ice until cloggs with frozen block ice
Works mechanically fine except for leaking.
johnpius is offline   Reply With Quote
Old 03-17-2008, 12:47 PM   #2
If the water is not shutting off to the ice maker it could be a sticky water valve or a water pressure problem.
The water pressure has to be at least 20 psi.
If you have a water dispense in the front of the fridge and it is working you can rule out the water pressure being a problem.
If you require a new valve you can get your Frigidaire parts here.
girltech is offline   Reply With Quote
Copper tubing for icemaker? BigJimmy Plumbing 15 09-11-2011 02:23 PM
How to monitor for leaks in a crawl space? twilightcall Plumbing 3 01-05-2008 11:38 PM
whirlpool icemaker problem pbl1962 Appliances 2 12-26-2007 02:07 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
T&G Floor Leaks newguy4 General DIY Discussions 2 11-07-2005 10:24 AM
