Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-11-2011, 07:57 PM   #1
Icemaker Diagnosis Help
I hava an Amana SSD25NBW side by side fridge, about 16 years old. In-door icemaker and water. The icemaker is not getting water. The water dispenser works fine.
The water supply hose in the freezer did not look blocked, but I unplugged and thawed out the fridge/freezer anyways. No change.
There are two solenoid in the back. They both read 340 ohms.
When I plug in the fridge, I don't see a voltage at the icemaker supply solenoid.
There is no water filter.
I need some help tracking down the problem. What next ?
SPS-1 is online now   Reply With Quote
Old 11-11-2011, 09:19 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
you will not see voltage at the valve until the icemaker is cycling and calling for water. does the icemaker run? If so I would suspect the valve.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 11-11-2011, 11:02 PM   #3
Not sure.
I stuck a couple of strips of paper on the ejector fingers. Will check it again tommorow morning and see if it looks like it has cycled.
The ice bucket is empty, it should be at least trying to make ice.
Old 11-12-2011, 10:32 AM   #4
Yes, icemaker is cycling. Most likely the valve then.
The coils seemed good, so it seemed it was a mechanical jam, so I opened up the solenoid to see if I could clean it. Unfortunately, the rubber seal is deformed and cracked.
Lets see if I can find a new water valve in town on a Saturday.
Hooking up water to an icemaker? (with a twist) CoconutPete Appliances 6 12-08-2010 06:10 AM
How do you hook up a water line for in icemaker? kennykenny Plumbing 8 06-22-2010 04:23 PM
Kenmore icemaker problem bikercraig Appliances 1 08-12-2009 09:12 PM
whirlpool icemaker wiring question dannyb Appliances 3 03-28-2009 09:45 PM
whirlpool icemaker problem pbl1962 Appliances 2 12-26-2007 03:07 PM
