Icemaker - Appliances - DIY Chatroom Home Improvement Forum
Old 09-14-2012, 12:54 PM   #1
icemaker
installed new water filter and auger drum on Whirlpool ED5FHG and it stopped making ice, workrd fine before.
Pubster64 is offline   Reply With Quote
Old 09-14-2012, 01:49 PM   #2
Rewards Points: 1,298
If it worked fine then why did you fix it?
Turn the water back on
danpik is offline   Reply With Quote
Old 09-16-2012, 06:23 PM   #3
Bombastic Idiot
notmrjohn's Avatar
lot of icemaker questions today. Lot of curt wise A answers too. But dan's right, is the filter firmly in place? Are you getting water from dispenser if equipped? Are you getting water to icemaker? All electrical connections back in place? And just why did you fix it?
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-18-2012, 01:02 PM   #4
ice maker
Didnt repair ice maker repaired broken auger for the ice dispenser never touched ice maker only the bin that holds the ice water is on and dispenses but stopped making ice
Old 09-18-2012, 02:20 PM   #5
Bombastic Idiot
notmrjohn's Avatar
Ok I'm still a bit confused. A normal state for me and due to my poorly worded question. "bin that holds the ice water" Do you mean water is entering the ice maker compartment but not freezing? if so the freezer may not be cold enuff. There is a heating element that thaws ice enuff for it to be released from maker, it may be stuck in on position. Timer, motor, or thermostat may be stuck.
Does auger turn?
Take a look here, see if it helps, http://www.appliancerepair.net/refri...-repair-8.html
Can I remove wire arm from icemaker boandbob Appliances 4 12-12-2011 05:04 AM
Icemaker Diagnosis Help SPS-1 Appliances 3 11-12-2011 09:32 AM
How do you hook up a water line for in icemaker? kennykenny Plumbing 8 06-22-2010 03:23 PM
whirlpool icemaker wiring question dannyb Appliances 3 03-28-2009 08:45 PM
whirlpool icemaker problem pbl1962 Appliances 2 12-26-2007 02:07 PM
