Ice Maker Won't Fill, Frozen Inlet Line - Appliances - DIY Chatroom Home Improvement Forum
Old 09-10-2011, 12:36 PM   #1
ice maker won't fill, frozen inlet line
how do I get to the inlet valve to check if it is closing all the way? my ice maker won't fill because it is frozen. Is it the solenoid or the inlet valve itself?
xplorin2 is offline   Reply With Quote
Old 09-10-2011, 01:27 PM   #2
Experienced
Jackofall1's Avatar
Hello and welcome xplorin2, to the best darn DIY'r site on the web.
Unfortunately, not all fridges are the same, so without some additional information it would impossible to answer your question.
Mark
Old 09-10-2011, 02:07 PM   #3
Rewards Points: 190
I just had a service call on my icemaker. Turns out the icemaker was OK but the saddle valve flow over time became restricted. Tech disconnected the water line at the solenoid valve and ran the water into a bucket. There was very little flow and he said that is why the line was freezing up. He disconnected the line from the other side of the solenoid valve. Then we had a power outage so the line thawed out. When the power came back I put in a new supply valve and put it all back together and now I have ice.
zircon is offline   Reply With Quote
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 09:03 AM
Sub pump line frozen outside LOUSY CARPENTER Plumbing 1 02-13-2011 08:53 AM
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 08:02 PM
Frozen cold line, not hot... Unregistered Plumbing 1 06-08-2006 07:42 AM
