Ice Maker Water Tube Frozen Solid - Appliances - DIY Chatroom Home Improvement Forum
Old 06-11-2011, 09:33 PM   #1
CDH
Rewards Points: 29
Ice maker water tube frozen solid
This has probably been covered before and if so sorry for not being able to find it but I have a Whirlpool side by side refridgerator freezer and the icemaker has quit working, looking at it for the first time I notice right off the bat that the tube that fills the icemaker with water looks to be frozen solid. Other than the obvious way of opening the freezer and letting it thaw out, is there a better away? And what would cause this line to do this? Thank's in advance for any help or advice.
CDH is offline   Reply With Quote
Old 06-12-2011, 07:24 PM   #2
Household Handyman
Rewards Points: 1,408
Hair dryer does work to thaw the fill tube. The fill tube will most likely freeze if the water control valve has a tiny leak causing the fill tube to have a constant, but slow supply of water.
Heil GNE075B12 Water in teh tube between combustion blower and pressure switch Quin HVAC 51 01-04-2013 12:46 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 06:26 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
No water to dispenser or ice maker Shannicole Appliances 5 05-12-2008 08:17 PM
