Ice Maker Tubing - Appliances - DIY Chatroom Home Improvement Forum
Old 07-17-2011, 10:05 PM   #1
ice maker tubing
Is vinyl tubing the wrong tubing to use for an ice maker or will the taste that is in the ice eventually go away? Thanks
florpro is offline   Reply With Quote
Old 07-18-2011, 12:59 AM   #2
General Contractor
If it's a new fridge it's recommended to throw away the first couple/few batches of ice. A filter either before the fridge or built into the fridge on some models will also help.
Do you mean your supply line to the fridge is plastic? Shouldn't affect the taste.....though as with any other new feed system added I'd be sure to bleed it out before hooking it up to the fridge.
dsconstructs is offline   Reply With Quote
Old 07-18-2011, 05:09 AM   #3
You mean plastic-not vinyl, correct?? if that's the cause you should also have off tasting water from dispenser. if only ice is a problem it's likely due to picking up odors from stored food or plastic bags. no model/serial # so assume this is new refrig.. dump all the ice and as soon as you get new ice-see if that is bad. ..If you want to do this job properly with no future service problems due to install; use copper or s/s supply with a regular shut off valve.
Jacques is offline   Reply With Quote
Old 07-18-2011, 08:35 AM   #4
It is a clear vinyl tubing and the refrigerator does not have a dispenser
Old 07-18-2011, 12:53 PM   #5
bsa_bob
Rewards Points: 150
Mines been plastic for 18 years, no problems. btw where do you find 8' of 1/4" ss line???????????? and the problem i would think with ss would be Everytime you move your frig out to clean'[least once a year] that darn ice making line is moving around all over the place. thats when it wears out.and cracks Vinyl doesn't lend itself to this cracking very often.They come packaged , with vinyl line ,i'm sure they have tested its worthiness a few times. hth
bsa_bob is offline   Reply With Quote
Old 07-18-2011, 01:34 PM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,586
stainless steele braided supply lines come in just about any length you want and they are not stiff and rigid they are flexable, way better than plastic. I can not count the number of times that I have run service for a broken plastic supply line, I would never have one. I do know that some insurance companies are now banning its use because of the millions of dollars in claims.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is online now   Reply With Quote
Old 07-18-2011, 05:07 PM   #7
Rewards Points: 150
You can use copper also.
josall is offline   Reply With Quote
Old 07-18-2011, 07:13 PM   #8
bsa_bob
Rewards Points: 150
Insurance claims on plastic tubing, don't seem to be a problem around mich, Stainless steel ---i think copper would be the best bet if i was to replace mine, or plastic again for another 18 years, To each is own. i said plastic the second time----theres a huge difference in plastic and vinylized plastic tubing, I had a yellow clear plastic line on one of my showbikes-i had a couple guys metion the fact to me that the plastic hardens with heat,therefors cracks..First time stainless crinkles into a 90 while making nice neat bends , it would not stay for the next bend,to do the same thing!! a novice will have a hard time with hard line. Jmo
Old 07-18-2011, 10:05 PM   #9
#1 HAWKEYE FAN
what part of flexible braided stainless did you not understand?
Old 07-18-2011, 10:41 PM   #10
MikeKy55's Avatar
Rewards Points: 254
As a DIY'r I opt for copper tubing. I had one of the kids hamsters get out one night and the dog woke me about 3AM so I would know it wasn't her who put the 1/2" of water throughout the kitchen and mud room.
MikeKy55 is offline   Reply With Quote
Old 07-18-2011, 10:49 PM   #11
General Contractor
I purposely avoided commenting on the plastic line the first time, now for my vote.
My preference on the subject.....rigid copper from below (obviously unless it's slab) up through the wall into a flush mount box w/shutoff and braided stainless line to the fridge.
Next is flexible copper, then plastic....
If it's a slab and has to be ran from from elsewhere, from under the sink with dual outlet shutoff valve.
NO saddle valves EVER
Old 07-18-2011, 11:49 PM   #12
jschaben
Rewards Points: 502
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 07-19-2011, 07:03 PM   #13
bsa_bob
Rewards Points: 150
Why do you suppse they would put the plastic tubing and the saddle valve, in the box you get with the ice.maker in it?? Its beyond me!
Old 07-19-2011, 07:12 PM   #14
bsa_bob
Rewards Points: 150
Sorry i just had never seen 10' long flexible s/s tubing.Didn't mean to p-you off. for that matter i have never seen s/s solid that long either.
Copper tubing for icemaker? BigJimmy Plumbing 15 09-11-2011 03:23 PM
Buried Copper LP Tubing Earnie Plumbing 1 02-22-2011 09:22 PM
How tight for Poly tubing? Ultrarunner2017 Plumbing 4 03-26-2009 08:41 AM
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 09:02 PM
Kenmore ice maker acting strange BJLower Appliances 3 10-25-2008 12:14 AM
