Ice Maker Troubleshoot Help - Appliances - DIY Chatroom Home Improvement Forum
Old 02-24-2014, 10:38 AM   #1
ice maker troubleshoot help
What's wrong with my icemaker?
Unit is a Frigidaire freezer on-top with hard-mold icemaker, it has the wire metal "arm" that moves during the cycle.
The fill cycle seems fine, as does the freeze cycle. The harvest cycle is the problem. The unit won't harvest the ice. Formed ice will sit in the mold forever.
HOWEVER, I can get it to go into harvest cycle by just SLIGHTLY (just a light tap) of the "arm" towards the icemaker. It's like the arm is hung-up a fraction of an inch before the harvest cycle.
This is a new install - however the icemaker is 8 years old - it was never plumbed unitll a few days ago.
sorethumber is offline   Reply With Quote
Old 02-24-2014, 10:48 AM   #2
Rewards Points: 14,312
Need the model# for better answers.
Old 02-24-2014, 11:31 AM   #3
Of the refigerator/freezer or the ice maker?
I thought these icemakers were standard across many models of refrigerators.
It looks exactly like this pic, and it has the spring loaded cam screw under the cover for water level adjustment.
Old 02-24-2014, 07:01 PM   #4
chitownken's Avatar
Rewards Points: 510
That arm is used to tell the icemaker when the container is full. It operates a microswitch inside the unit that must close for the harvest cycle to start. If the switch is stiff or the spring on the arm is weak, it might not depress the switch enough to close the contacts. If the arm has been in the up position for 8 years, it might have weakened the spring. You can take the front cover off of the icemaker (unplug it from the fridge first) and gently wind up that spring one more turn to give it more force on the switch. Not sure that you can order just that spring.
chitownken is offline   Reply With Quote
The Following User Says Thank You to chitownken For This Useful Post:
sorethumber (02-25-2014)
Old 02-25-2014, 08:30 AM   #5
Thank you! I'll check that out ASAP.
And yes, the arm has been up for approx. 8 years.
Old 06-11-2014, 02:07 PM   #6
FYI, follow-up, winding the spring one revolution worked perfectly. I've been enjoying a perfectly functioning ice maker for the about the last 4 months!
Old 06-11-2014, 06:57 PM   #7
Rewards Points: 402
Sorry, old post. Glad it's working.
taylorjm is offline   Reply With Quote
Ice Maker Italgrl Appliances 2 02-06-2014 12:17 PM
Ice maker will not eject ice BIG DIY'ER Appliances 3 07-16-2012 03:20 PM
whirlpool GS6SHEXNS00 ice maker not working houseof5dogs Appliances 1 05-06-2011 08:28 PM
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 08:02 PM
Kenmore ice maker acting strange BJLower Appliances 3 10-24-2008 11:14 PM
