Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 03-20-2011, 05:08 PM   #1
Ice Maker Stopped Working
I have a Kenmore Coldspot model no. 51562101 and a couple months ago our ice maker stopped working. Water still comes out of it but it doesn't make ice any longer. I haven't tried fixing it yet and was reading through a few forums and it sounds like the likely problems are a frozen line and a frozen water inlet valve. I'm not sure how I would check out the solenoid. Is there any thing else I should check out or should I just pull out the ice maker then any lines I see inside the refrigerator. Then do I need to check the water inlet valve? I wasn't sure since I am getting water out of the front of the refrigerator if it could be the water inlet valve? Does anyone have a service manual for the ice maker that comes on this fridge? Any help would be much appreciated.
bsmith95610 is offline   Reply With Quote
Old 03-20-2011, 08:14 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
does the icemaker cycle?? icemaker motor may be bad, other possabilities would be the water valve, or maybe a frozen fill tube. first step would be to see if the icemaker cycles then go from there.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 03-20-2011, 08:26 PM   #3
When you say does the icemaker cycle. How would I test that out?
Old 03-20-2011, 10:25 PM   #4
Turn it on and watch it?
msaeger is offline   Reply With Quote
Old 03-20-2011, 11:05 PM   #5
What does it mean does the icemaker cycle?
Old 03-20-2011, 11:12 PM   #6
#1 HAWKEYE FAN
have you ever seen the icemaker going through a cycle? I can tell you how to advance it into a cycle but I would have to know if it is the old style icemaker or the newer style with an electronic module.
Old 03-20-2011, 11:37 PM   #7
Attached is a picture of the ice maker I don't know if this will help you tell if this is a newer one or an older one. When you saying going through the cycle are you just talking about making ice? It doesn't make ice at all currently.
Old 03-20-2011, 11:48 PM   #8
#1 HAWKEYE FAN
ok that helps, the ice bucket is in the door right? call a qualified service tech. Unless you are real handy thats not really a DIY repair, but I can tell you that those icemakers have a high failure rate.
Old 03-21-2011, 12:05 AM   #9
Yes, the ice bucket is in the door. Should I even bother checking the lines to make sure they aren't frozen or would that probably be a waste of time?
Old 03-21-2011, 11:30 AM   #10
#1 HAWKEYE FAN
yeah, pretty much a waste of time.
Receptacle stopped working lovetobuild Electrical 3 02-11-2011 11:05 AM
Ice maker stopped working. HomerH209 Appliances 3 11-10-2010 08:54 PM
Ice Maker stopped working Whirlpool ED5FHEXNQ00 Hotlatte Appliances 1 05-14-2009 04:15 PM
Whirlpool Icemaker Stopped Working jablizz General Discussion 1 07-19-2008 09:38 PM
Ice maker stopped working bragl01 Appliances 3 08-07-2006 09:59 PM
