-   -   Ice Maker Stopped Working (http://www.diychatroom.com/f47/ice-maker-stopped-working-99003/)
bsmith95610 03-20-2011 04:08 PM
I have a Kenmore Coldspot model no. 51562101 and a couple months ago our ice maker stopped working. Water still comes out of it but it doesn't make ice any longer. I haven't tried fixing it yet and was reading through a few forums and it sounds like the likely problems are a frozen line and a frozen water inlet valve. I'm not sure how I would check out the solenoid. Is there any thing else I should check out or should I just pull out the ice maker then any lines I see inside the refrigerator. Then do I need to check the water inlet valve? I wasn't sure since I am getting water out of the front of the refrigerator if it could be the water inlet valve? Does anyone have a service manual for the ice maker that comes on this fridge? Any help would be much appreciated.
hardwareman 03-20-2011 07:14 PM
does the icemaker cycle?? icemaker motor may be bad, other possabilities would be the water valve, or maybe a frozen fill tube. first step would be to see if the icemaker cycles then go from there.
bsmith95610 03-20-2011 07:26 PM
When you say does the icemaker cycle. How would I test that out?
msaeger 03-20-2011 09:25 PM
Turn it on and watch it?
bsmith95610 03-20-2011 10:05 PM
What does it mean does the icemaker cycle?
hardwareman 03-20-2011 10:12 PM
have you ever seen the icemaker going through a cycle? I can tell you how to advance it into a cycle but I would have to know if it is the old style icemaker or the newer style with an electronic module.
bsmith95610 03-20-2011 10:37 PM
1 Attachment(s)
Attached is a picture of the ice maker I don't know if this will help you tell if this is a newer one or an older one. When you saying going through the cycle are you just talking about making ice? It doesn't make ice at all currently.
hardwareman 03-20-2011 10:48 PM
ok that helps, the ice bucket is in the door right? call a qualified service tech. Unless you are real handy thats not really a DIY repair, but I can tell you that those icemakers have a high failure rate.
bsmith95610 03-20-2011 11:05 PM
Yes, the ice bucket is in the door. Should I even bother checking the lines to make sure they aren't frozen or would that probably be a waste of time?
hardwareman 03-21-2011 10:30 AM
yeah, pretty much a waste of time.
