Ice Maker Problems - Appliances - DIY Chatroom Home Improvement Forum
Old 07-15-2011, 07:22 PM   #1
Ice maker problems
I'm having a problem with the ice maker in my Kicthen aid refrigerator. The water does not refill the tray after it cycles. I've jumped test points V to L and the water does dispense into the tray as long as the jumper is connected. I have replaced the ice maker with a new unit and still have the same problem. I could really use some help.
roadruner
roadruner is offline   Reply With Quote
Old 07-15-2011, 09:48 PM   #2
I think you'll have better luck if you move this to the appliance section.
VIPlumber is offline   Reply With Quote
Old 07-16-2011, 07:34 AM   #3
Rewards Points: 1,216
Sounds like the cams inside the ice machine are not making contact when calling for refill. Buy another ice maker plug it in and wait.
COLDIRON is offline   Reply With Quote
Old 07-16-2011, 08:29 AM   #4
An old Tradesmen
Rewards Points: 6,464
Moved to appliance forum. Should be able to gt help here.
Tags
icemaker , refrigerator repair
Frigidaire ice maker problems Lawayne Appliances 0 07-09-2011 09:58 AM
ice maker problems chapman22 Appliances 0 08-29-2010 11:39 AM
Is this forum for refrigeration too? Ice maker problems thunderhead Appliances 3 03-01-2010 06:00 AM
GE Ice maker problems dee1215 Appliances 2 05-17-2009 09:19 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 03:04 PM
