Ice Maker Plug - Appliances - DIY Chatroom Home Improvement Forum
Old 01-25-2011, 08:49 AM   #1
Question
Ice Maker plug
I have tried pulling out the plug and it will not release. Is there some trick to pulling out the plug?
bigtink is offline   Reply With Quote
Old 01-25-2011, 10:09 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,584
Question
what plug are you talking about?
hardwareman is offline   Reply With Quote
Old 01-25-2011, 10:24 AM   #3
Ice maker
I am talking about the ice maker plug. It seems that the rubber around it was glued in place.
Old 01-25-2011, 10:51 AM   #4
#1 HAWKEYE FAN
your going to have to provide a little more info. Ice maker plug as in power, or your trying to install a new icemaker and need to get the plug out of the back to install water line?? How old ? Brand? I'm going to assume your talking about power and just tell you it is not glued in, probably will have two little tabs you need to squeeze and then pull.
Old 01-25-2011, 11:05 AM   #5
Whirlpool Estate ice maker
The plug I am talking about is inside the freezer and it is the ice maker electric plug. It has a rubber gasket around it and that is glued to the freezer. It is not a prong that is the problem it is the rubber gasket around the plug that is glued. Thank you.
Old 01-25-2011, 11:10 AM   #6
#1 HAWKEYE FAN
never seen any thing like that before, what is the brand and model # would be very helpful
Old 01-25-2011, 11:27 AM   #7
Whirlpool Estate
It is a Whirlpool Estate model TS25AFXKQ03. I have never seen anything like this before. Of course this is the first time for me to try to replace an ice maker so it is not just undoing three screws and unplugging the old unit. I have been gradually working my way around it trying to loosen it up. I cannot believe they would glue this part in. Thank you.
Old 01-25-2011, 12:25 PM   #8
#1 HAWKEYE FAN
ok now I understand, I forgot about the newer Whirlpool products. First stop trying to unplug it there!!! That is part of the cabinet wiring, hope you haven't damaged the wires already. Remove the plug AT the icemaker itself
Old 01-25-2011, 12:42 PM   #9
Icemaker
So you mean that I have to pull the old wiring out of the old icemaker at the icemaker part and use the old wiring with the new ice maker? No I have not damaged the wiring yet. Thank you
Old 01-25-2011, 12:47 PM   #10
#1 HAWKEYE FAN
it is a quick disconnect plug at the icemaker, 1 push in tab directly in the middle will release it from the icemaker.
Old 01-25-2011, 12:52 PM   #11
Ice maker
Thank you I will let you know if this works.
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 08:48 AM
Replacement plug for an old box freezer brich Electrical 1 05-11-2010 07:44 AM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 10:49 AM
20 amp plug MikeyP Electrical 6 01-03-2009 10:04 PM
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 09:02 PM
