-   -   Ice Maker plug (http://www.diychatroom.com/f47/ice-maker-plug-93440/)
bigtink 01-25-2011 08:49 AM
Ice Maker plug
I have tried pulling out the plug and it will not release. Is there some trick to pulling out the plug? :whistling2:
hardwareman 01-25-2011 10:09 AM
what plug are you talking about?
bigtink 01-25-2011 10:24 AM
Ice maker
I am talking about the ice maker plug. It seems that the rubber around it was glued in place.
hardwareman 01-25-2011 10:51 AM
your going to have to provide a little more info. Ice maker plug as in power, or your trying to install a new icemaker and need to get the plug out of the back to install water line?? How old ? Brand? I'm going to assume your talking about power and just tell you it is not glued in, probably will have two little tabs you need to squeeze and then pull.
bigtink 01-25-2011 11:05 AM
Whirlpool Estate ice maker
The plug I am talking about is inside the freezer and it is the ice maker electric plug. It has a rubber gasket around it and that is glued to the freezer. It is not a prong that is the problem it is the rubber gasket around the plug that is glued. Thank you.
hardwareman 01-25-2011 11:10 AM
never seen any thing like that before, what is the brand and model # would be very helpful
bigtink 01-25-2011 11:27 AM
Whirlpool Estate
It is a Whirlpool Estate model TS25AFXKQ03. I have never seen anything like this before. Of course this is the first time for me to try to replace an ice maker so it is not just undoing three screws and unplugging the old unit. I have been gradually working my way around it trying to loosen it up. I cannot believe they would glue this part in. Thank you.
hardwareman 01-25-2011 12:25 PM
ok now I understand, I forgot about the newer Whirlpool products. First stop trying to unplug it there!!! That is part of the cabinet wiring, hope you haven't damaged the wires already. Remove the plug AT the icemaker itself
bigtink 01-25-2011 12:42 PM
Icemaker
So you mean that I have to pull the old wiring out of the old icemaker at the icemaker part and use the old wiring with the new ice maker? No I have not damaged the wiring yet. Thank you
hardwareman 01-25-2011 12:47 PM
it is a quick disconnect plug at the icemaker, 1 push in tab directly in the middle will release it from the icemaker.
bigtink 01-25-2011 12:52 PM
Ice maker
Thank you I will let you know if this works.
