Ice Maker Overfilling - Appliances - DIY Chatroom Home Improvement Forum
Old 01-06-2013, 12:16 PM   #1
Rewards Points: 80
I have an Amana refrigerator with top freezer and ice maker (IC6).
The water fill cycle is to long and allows water to go into the harvest bin.
I cannot locate the adjustment screw for cube size/water fill time.
I am not certain this model has a adjustment screw? I have the front cover off, but see nothing marked +/-.
Any suggestions appreciated.............John V.
Ice Maker Overfilling-img_0618.jpg   Ice Maker Overfilling-img_0619.jpg   Ice Maker Overfilling-img_0620.jpg
Old 01-06-2013, 03:26 PM   #2
Rewards Points: 13,276
http://www.acmehowto.com/howto/appli...agicemaker.php
Old 01-06-2013, 10:47 PM   #3
Rewards Points: 240
That little plastic pin on the side is the adjustment screw. However, typically it does not have a lot of range. When I had that happen before, the problem was with the water valve -- it was getting hung open, and it took 10-15 seconds to close after the solenoid de-energized. You might want to observe a cycle, listen for the hum from the solenoid, and note whether the water stops when the hum does, or keeps running.
fa_f3_20 is offline   Reply With Quote
Old 01-07-2013, 08:57 AM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
the white screw on the side is the adjustment, turn clockwise to decrease. Max range is 1 full turn before damaging unit.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-11-2013, 12:56 AM   #5
That screw is for adjusting the size of the cube and thats all. If its over flowing there is another reason for it. Most likley water valve make sure its repalced with the one for that model. Model determines how many cc's of water for your particular i/m.
rkentzel is offline   Reply With Quote
Ice maker will not eject ice BIG DIY'ER Appliances 3 07-16-2012 04:20 PM
whirlpool GS6SHEXNS00 ice maker not working houseof5dogs Appliances 1 05-06-2011 09:28 PM
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 09:02 PM
Kenmore ice maker acting strange BJLower Appliances 3 10-25-2008 12:14 AM
Ice Maker problem. sflamedic Appliances 5 08-25-2008 06:28 AM
